Re: GRRRR. No such thing as 27/28" tall front runners
[Re: CMcAllister]
#3187824
10/31/23 11:51 AM
10/31/23 11:51 AM
Posts: 4,775 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Goodyear D1966, Hoosier 18112, M/T 3002 Thanks but I'm looking for DOT approved full time street tire. Steel or fiberglass radial construction. Members on this post have provided tires I was not aware of.
Keep old mopars alive.
[Re: johnnycuda]
#3187827
10/31/23 11:56 AM
10/31/23 11:56 AM
2boltmain
Holland MI Ottawa
I know these aren't a drag race type front runner, but I have Hancook Optimo tires on my 'Cuda, size is 205/75-15, roughly 28" tall, mounted a 4" wide Weld wheel, they are a radial, my car is over 3800lbs with me in it, runs mid-to high 10's, is street driven mostly, due to lack of tracks and time, so I have a few thousand miles on these so far, no issues. Thanks. For a 205 series the Hankook Optimo has the height I want.
[Re: 2boltmain]
#3187829
10/31/23 12:01 PM
10/31/23 12:01 PM
Posts: 860 lancaster,california
johnnycuda
I know these aren't a drag race type front runner, but I have Hancook Optimo tires on my 'Cuda, size is 205/75-15, roughly 28" tall, mounted a 4" wide Weld wheel, they are a radial, my car is over 3800lbs with me in it, runs mid-to high 10's, is street driven mostly, due to lack of tracks and time, so I have a few thousand miles on these so far, no issues. Thanks. For a 205 series the Hankook Optimo has the height I want. You're welcome, they work well for me, my buddy put a set on his 10-sec Coronet once he saw them, as he didn't like the Sportsman tires either.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: 2boltmain]
#3187845
10/31/23 12:45 PM
10/31/23 12:45 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
Thank you I saved that to my favorites. I had looked on Cokers site but evidently not good enough. That price is high but everything in this hobby is expensive. I hope I can strike a deal with an on the fence seller I found on Market Place. He has 15x4 draglites with brand new 27" tall SR Sportsmans but he doesn't want to break up the 4 piece set. I only need the fronts. Buy them and sell the rears ?
[Re: 2boltmain]
#3187855
10/31/23 01:35 PM
10/31/23 01:35 PM
Posts: 1,891 Spahn Ranch
RMCHRGR
Spahn Ranch
Goodyear D1966, Hoosier 18112, M/T 3002 Thanks but I'm looking for DOT approved full time street tire. Steel or fiberglass radial construction. Members on this post have provided tires I was not aware of. M/T came out with these radial front runners recently, they are available in 28". Availability seems hit or miss but Summit says they have 16 in stock right now. Not cheap! https://www.summitracing.com/parts/mtt-3880
'71 Duster '17 Ram 1500
[Re: RMCHRGR]
#3187997
11/01/23 09:54 AM
11/01/23 09:54 AM
JohnRR
U.S.S.A.
Goodyear D1966, Hoosier 18112, M/T 3002 Thanks but I'm looking for DOT approved full time street tire. Steel or fiberglass radial construction. Members on this post have provided tires I was not aware of. M/T came out with these radial front runners recently, they are available in 28". Availability seems hit or miss but Summit says they have 16 in stock right now. Not cheap! https://www.summitracing.com/parts/mtt-3880 That's for an 18" rim , he's looking for 15" rim options
[Re: 2boltmain]
#3188046
11/01/23 01:55 PM
11/01/23 01:55 PM
2boltmain
Holland MI Ottawa
JohnRR said: "Buy them and sell the rears ?" His rears are 28 x10 x15 tires on a 15x8 wheel. My rears are SIGNIFICANTLY larger at 29x15.5x15 tires on a 15x12 wheel.
[Re: JohnRR]
#3188061
11/01/23 02:47 PM
11/01/23 02:47 PM
RMCHRGR
Spahn Ranch
That's for an 18" rim , he's looking for 15" rim options Whoops, totally missed that. Sorry for the bad info. I have those tires myself for 15" rims but they are only 26" diameter. Summit does show eight of the 28x6-15 S/R front runner tires currently in stock, go get 'em. M/T S/R 28/6-15
