69 roadrunner a pillar seal...too big ?? #3183021
10/11/23 11:30 AM
10/11/23 11:30 AM
NORTHERN VA
THESHAKERPROJECT Offline OP
NORTHERN VA
Trying to replace the old seal on conv RR on A pillar and the seal looks to be way to thick (SOFT SEAL ) IS there a trick to installing them and getting them to fit ?? Is there a better brand that fits ?? Tried silicon and soapy water and I cannot get them in the channel.....
Re: 69 roadrunner a pillar seal...too big ?? [Re: THESHAKERPROJECT] #3183026
10/11/23 11:41 AM
10/11/23 11:41 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Try K-Y jelly. I started using that years ago to put windshields in and it works better than anything else I've tried.
Re: 69 roadrunner a pillar seal...too big ?? [Re: THESHAKERPROJECT] #3183455
10/12/23 07:06 PM
10/12/23 07:06 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Soft Seal has let me down several times now. Especially A bodies. Their stuff for them simply does not fit.
I now use Steele. www.steelerubber.com/automotive
Master, again and still
Re: 69 roadrunner a pillar seal...too big ?? [Re: DaveRS23] #3183666
10/13/23 03:30 PM
10/13/23 03:30 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I have to agree. Metro makes some great products but Steele makes the best of a few items. All thier convertible parts are very good. I worked for over 2 years on the E body convertible stuff. The SoffSeal E body convertible parts were not even sellable. The other items were hard as a rock. I used them on my own car before I learned better. Looks like Classic must have bought out the Soffseal stuff. At least the Mopar stuff. Ouch.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 69 roadrunner a pillar seal...too big ?? [Re: 71TA] #3183880
10/14/23 12:29 PM
10/14/23 12:29 PM
NORTHERN VA
NORTHERN VA
Think I had same problem with door seals from Soft seal some years ago so will try the Steele rubber stuff . Thanks !
Re: 69 roadrunner a pillar seal...too big ?? [Re: THESHAKERPROJECT] #3187320
10/29/23 11:52 AM
10/29/23 11:52 AM
NORTHERN VA
NORTHERN VA
I have now fitted the new STEELE rubber prod ones and they fit perfectly !!
Re: 69 roadrunner a pillar seal...too big ?? [Re: THESHAKERPROJECT] #3187797
10/31/23 09:22 AM
10/31/23 09:22 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
