Page 2 of 4 1 2 3 4
Re: New F.A.S.T smallblock record!!! [Re: JohnRR] #3187635
10/30/23 01:31 PM
10/30/23 01:31 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
My major "observation" with all my association with FAST is that even where you are allowed to run an aftermarket block (Hemi's and BB Chevies are allowed due in large part to scarcity) in my opinion you should still be limited to a maximum of .060" over the FACTORY Bore size. IMO it's an unfair advantage to be allowed a 4.56" bore for the Hemi/L87-L89 cars if only because a guy with a small block anything or a Pontiac or any other brand can't. Bigger bores mean bigger valves and the 'already fast' combos get that much faster.
WIZE
In Car:
Re: New F.A.S.T smallblock record!!! [Re: 2boltmain] #3187637
10/30/23 01:33 PM
10/30/23 01:33 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
They should have a small block class for cars that could have been purchased with a supercharger option either direct ,or dealer installed. Mr. Norm's 340 Demon, Early Shelby Mustangs, and even the few Studebaker's that came with them.
Re: New F.A.S.T smallblock record!!! [Re: Neil] #3187639
10/30/23 01:44 PM
10/30/23 01:44 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Studebakers have run in F.A.S.T. as I recall.
'63 Dodge 330
11.19 @ 121 mph
Re: New F.A.S.T smallblock record!!! [Re: GY3] #3187669
10/30/23 03:43 PM
10/30/23 03:43 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I think the R2 Studebaker Larks that race are in the pure stock drag series, which is not the same as the FAST group???
https://youtu.be/rnq7uJcgJug?si=zgBXkQfroSrEdn8E
Re: New F.A.S.T smallblock record!!! [Re: Neil] #3187676
10/30/23 04:37 PM
10/30/23 04:37 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
You may be correct!
'63 Dodge 330
11.19 @ 121 mph
Re: New F.A.S.T smallblock record!!! [Re: GY3] #3187679
10/30/23 04:47 PM
10/30/23 04:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
There are two classes that run at the “FAST” events.
The original FAST……. factory appearing stock tire, and F/S…… factory stock.
F/S is basically the twin to the PSMCDR series, where the whole car is supposed to be pretty much “stock”.
One difference between the two organizations is that the PSMCDR series limits the ET to no quicker than 11.50, and F/S does not.
Re: New F.A.S.T smallblock record!!! [Re: Streetwize] #3187687
10/30/23 05:15 PM
10/30/23 05:15 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I don't know for sure but I believe the Duster is running an R block so 4.100" + would be no problem. The R block is heavier than a factory block too so there's a weight penalty.
'71 Duster
'17 Ram 1500
Re: New F.A.S.T smallblock record!!! [Re: fast68plymouth] #3187688
10/30/23 05:17 PM
10/30/23 05:17 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
What's impressive is that some of the F/S cars are running quicker than some of the old FAST cars.
I wonder how many people are actually running european spec 70MM exhaust? It's roughly 2.75" od, visually everyone can spot 3" pipe but it takes a pretty trained eye to spot the difference between 2 1/2" and 2 3/4"
WIZE
In Car:
Re: New F.A.S.T smallblock record!!! [Re: RMCHRGR] #3187699
10/30/23 05:54 PM
10/30/23 05:54 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Didn’t Ryan have a cnc program to lighten the R3 blocks years ago. I’m sure others do too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: New F.A.S.T smallblock record!!! [Re: pittsburghracer] #3187701
10/30/23 06:17 PM
10/30/23 06:17 PM
Lees Summit, MO
SmallHurst Offline
SmallHurst  Offline
Lees Summit, MO
Originally Posted by pittsburghracer
I wish I understood the rules more but from what I understand it’s not your everyday common compound street tire. Big cubic inches. Big manifolds modified of course. Are Grids aloud to pull timing??? Any head modification that aren’t legal??? Compression limits??? What rear suspension are they allowed? I’m guessing large. And are aloud. Any ring pac rules.
The tires are reproduction bias ply tires , nothing special about them other than they hook better than the originals, some people played with traction aiding substances but it didn't really help, track prep is very good when these cars run I assume ... I haven't run since '06
Yes it's over 400 CI ,
Stock 340 A body exh castings that can be ported and polished as they see fit, 2.5 inch max pipe size to the rear bumper, stock looking mufflers in stock location , straight thru ok , X pipe ok
No idea what the grids are but they are allowed to run a digital type ignition with a stock looking dist housing.
Compression there is no limit
Rear suspension is factory stock style leafs and a race shock , no caltrac type , no slapper bars
No ring pack rules, there is a cubic inch limit on big blocks , not sure what it is on a smallblock ?
Roller cams allowed , aftermarket rockers allowed but they need to fit under a stock type valvecover 2 gaskets , no spacers ... the valvecover rule does not apply to the BBC, they can run an aftermerket that is MUCH taller , no one makes one for other makes ? fan
Thanks. I know something cam up the up the other day that I think a 1/2 inch wider wheel was allowed which would help with the footprint. I’m assuming a 904 with lite weight parts are allowed also.
He can go one letter size larger on tire size over stock. If it started with an E70-14, he can go to a F70-14.
Snarl softly and carry a BIG stick 1969 Hurst/Olds Pure Stock 13.23@ 103.1 and the a/c blows cold! Rusty Small
Re: New F.A.S.T smallblock record!!! [Re: pittsburghracer] #3187702
10/30/23 06:17 PM
10/30/23 06:17 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I kinda remember that and recall it was a huge amount of work? The class rule makers would likely want you to keep the outside of the block looking 'factory' though so there's probably a limit on what you can do to it anyway. No motor plates in the class so the mount ears would have to stay and that's a bunch of weight right there. Most of the weight is in the block itself anyway with thicker main webbing and decks, lifter bosses, 4 bolt mains, etc.
'71 Duster
'17 Ram 1500
Re: New F.A.S.T smallblock record!!! [Re: Neil] #3187703
10/30/23 06:20 PM
10/30/23 06:20 PM
Lees Summit, MO
SmallHurst Offline
SmallHurst  Offline
Lees Summit, MO
The superchargers on the Studes were factory installed units. Not dealer added units. The Studes that have run have been in the Factory Stock/ Pure Stock ranks.
Re: New F.A.S.T smallblock record!!! [Re: SmallHurst] #3187714
10/30/23 07:40 PM
10/30/23 07:40 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Thanks Tom!
Slowly picking away at it. There's more in the combo, not sure how much more but it's not tapped out yet. It was nice to see some power improvements with the work I did over the last year. Basically it is the same short block 340 resto block .030 over with a stroker crank. Did quite a bit more of oil control modifications this time. New set of J heads cnc'd by KG and Porter Racing did the finishing and fine details. I ported another intake with more extra care in the plenum area, and I did another set of exhaust manifolds. I setup the valvetrain and spent way too much time moving things around to get the most out of cam. With making the passenger side exhaust manifold as thin as I dared, it's outlet is still only a touch over 1 7/8"! Also added 45lbs to the car over last year, which I hope to address this winter. I was over the moon it went 130 on a 80* day.
Also, just saying, the main reason for shaving the tires is to make them round. I appreciate Kelsey taking the time to make tires for the restoration crowd, and am not badmouthing them at all, but most of the reproduction tires I have had my hands on are out of round by over 2-3/32nds. You cannot balance them on a 14" rim, and at over 120+ it's not good.
Re: New F.A.S.T smallblock record!!! [Re: F1Scamp] #3187762
10/30/23 11:39 PM
10/30/23 11:39 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
Still one of the coolest classes in drag racing. I've come across this guys videos a few times, he goes over a lot of tech involved, and what they do to the tires. He takes a shot at hemi joel in this video regarding air cleaners lol
Re: New F.A.S.T smallblock record!!! [Re: scatpacktom] #3187783
10/31/23 07:59 AM
10/31/23 07:59 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Congrats to them...an impressive build!
Re: New F.A.S.T smallblock record!!! [Re: Dart 500] #3187785
10/31/23 08:03 AM
10/31/23 08:03 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
seems like pretty tight converters. Probably how they keep from spinning.on those suspensions/tires. Keep the power down in the launch with low rpm stall. Then have a bunch of low end torque to pull you out of it. shruggy
Re: New F.A.S.T smallblock record!!! [Re: pittsburghracer] #3187826
10/31/23 11:52 AM
10/31/23 11:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't know if a 1/2 wider wheel would make that big a difference , I believe that the 340 Duster had an E70-14 as the only available tire size so the max allowed size is a G70-14. As far as the lightweight 904 , yes that would be allowed. With a big block Mopar since there was not BB 904 case you can run the 904 guts in a 727 case. GM's are allowed to use a powerglide even if the engine being run never had one behind it ... If I remember right the L88 Vette run by Wayne Nelson back in 06 had a powerglide behind it ...
Re: New F.A.S.T smallblock record!!! [Re: SmallHurst] #3187828
10/31/23 11:57 AM
10/31/23 11:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Rusty I was pretty sure that was the case with PSMCDR, and Originally in FAST, but now I thought it went to a max of the G size ? Did the 340 Duster have an F series tire? I know my 69 383 gts was originally an E70 , I run F 70's , getting a G on it would not be easy, the F is tight with my rear springs sagging like they do.
Re: New F.A.S.T smallblock record!!! [Re: GY3] #3187830
10/31/23 12:03 PM
10/31/23 12:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by 6PKRTSE
The F.A.S.T class is awesome. One of my favorite classes of racing. All of these cars are impressive.
I read the rules and there are a lot of “grey” areas that you would have to learn and push to the limits. Are they allowed and do they shave their tires. Living close to Lernerville dirt track I know those guys have lots of tire tricks.
The consensus among those that have experimented with them is that they work best when shaved down to the wear bars and have minimal tread showing. No chemicals added.
Exactly , they actually run a SLICK TIRE event where everyone that wants to run their bald tires. Some tracks don't allow it , New England Dragway a couple years ago failed tech on one guy because at the inflation he was running his tire at the very center treadd bar had worn away the tread sipes , the rest of the tire was perfect and it wasn't near the wear bars. It looked like they wear you would see on a slightly over inflated tire with lots of miles , or burnouts, on it.
Re: New F.A.S.T smallblock record!!! [Re: 2boltmain] #3187831
10/31/23 12:04 PM
10/31/23 12:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by 2boltmain
Forums have the most knowledgeable members. But Face Book Groups have taken over. The FB Groups have NON knowledgeable members. I was reading the comments of this Duster on the FBG. The majority simply does not understand- "Factory Appearing Stock Tire." Many members dumbfounded and naysaying that a stock Duster 340 is so fast. It's not stock. Only thing stock is the appearance. That's the point. Gotta select a car and available drivetrain that will lend itself to heavy modifications internally to make BIG power. That's why the Hemi did so well in this class. Factory high flow heads- great induction and great flowing exh manifolds.
There is all kinds of stupid in the FBG
Page 2 of 4 1 2 3 4
