Re: New F.A.S.T smallblock record!!!
[Re: scatpacktom]
#3187306
10/29/23 11:06 AM
10/29/23 11:06 AM
Posts: 276 NY
aarmaniac
NY
First round the Duster went a little quicker.
F.A.S.T. Legal AAR Cuda 11.57 @ 118 mph 1.72 60"
[Re: Mr PotatoHead]
#3187566
10/30/23 09:30 AM
10/30/23 09:30 AM
Posts: 9,902 Weddington, N.C.
Streetwize
Weddington, N.C.
I remember 20 years ago suggesting to Tom Cannon and others in FAST 20 yrs ago that I thought a 71-72 340 TQ duster or demon would be a faster combo than a 70 Challenger six pack and might rival a hemi E or B body in terms of 60' and 1/8th mile times. I don't know if anyone remembers but I had actually bought a 72 duster Twister /6 car and a 340 and 904 with the hopes of building a 433" FAST car. but work sent me overseas for months so I sold the project. But I'm so glad someone else came through and Proved my prediction correct!! LOL congratulations!!, I don't know everything they are doing but I'll bet I have a pretty good guess! But I had figured out the cam 'secrets' a long time ago anyway, before some of them did! But the short front and long rear overhang and the light weight of the Duster make it the most natural Mopar Drag car there is, and the roofline is more aerodynamic than a Dart or 67-69 cuda body. 10.30's on 14" tires and factory castings....That's truly astounding!! I was thinking you could get a 71-72 duster to about a 2700-ish legit pounds and still pass FAST tech. BTW who did he run in the other lane that went 118 in the 1/8th and "only" 123.xx in the 1/4? Did he run out of nitrous 1/2 way down the track? ![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) (I'm just kidding!) Judging by ythe 1/8th mile that was a 9 second car so probably DD, 118 in the 1/8th would be way too slow to be a Pennington car! ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif)
[Re: scatpacktom]
#3187572
10/30/23 09:42 AM
10/30/23 09:42 AM
Posts: 1,620 MA
ragtop
MA
[Re: ragtop]
#3187590
10/30/23 10:51 AM
10/30/23 10:51 AM
Posts: 1,247 Loudoun County, VA
Brad_Haak
Loudoun County, VA
![green green](/ubbthreads/images/graemlins/custom/2231195-dggif.gif) + ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif) = ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) Well, my mind has completely exploded after seeing the above time slips
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3187595
10/30/23 11:11 AM
10/30/23 11:11 AM
Posts: 20,222 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I wish I understood the rules more but from what I understand it’s not your everyday common compound street tire. Big cubic inches. Big manifolds modified of course. Are Grids aloud to pull timing??? Any head modification that aren’t legal??? Compression limits??? What rear suspension are they allowed? I’m guessing large. And are aloud. Any ring pac rules.
[Re: pittsburghracer]
#3187600
10/30/23 11:28 AM
10/30/23 11:28 AM
Posts: 75,194 A Banana Republic near you.
JohnRR
The tires are reproduction bias ply tires , nothing special about them other than they hook better than the originals, some people played with traction aiding substances but it didn't really help, track prep is very good when these cars run I assume ... I haven't run since '06 Yes it's over 400 CI , Stock 340 A body exh castings that can be ported and polished as they see fit, 2.5 inch max pipe size to the rear bumper, stock looking mufflers in stock location , straight thru ok , X pipe ok No idea what the grids are but they are allowed to run a digital type ignition with a stock looking dist housing. Compression there is no limit Rear suspension is factory stock style leafs and a race shock , no caltrac type , no slapper bars No ring pack rules, there is a cubic inch limit on big blocks , not sure what it is on a smallblock ? Roller cams allowed , aftermarket rockers allowed but they need to fit under a stock type valvecover 2 gaskets , no spacers ... the valvecover rule does not apply to the BBC, they can run an aftermerket that is MUCH taller , no one makes one for other makes ? ![fan fan](/ubbthreads/images/graemlins/custom/fan.gif)
[Re: JohnRR]
#3187601
10/30/23 11:33 AM
10/30/23 11:33 AM
Brad_Haak
Loudoun County, VA
Link to rules: https://www.fastdrags.com/fast-rulesThe cars I've seen follow the "stock appearing" part very closely. However, I gotta call bogus on the "stock sound" requirement cuz some of those cars OBVIOUSLY have way more cam than any OEM I've ever heard. They might as well just drop that, cuz according to my ears, it's not being enforced anyway.
[Re: JohnRR]
#3187603
10/30/23 11:45 AM
10/30/23 11:45 AM
Posts: 20,222 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The tires are reproduction bias ply tires , nothing special about them other than they hook better than the originals, some people played with traction aiding substances but it didn't really help, track prep is very good when these cars run I assume ... I haven't run since '06 Yes it's over 400 CI , Stock 340 A body exh castings that can be ported and polished as they see fit, 2.5 inch max pipe size to the rear bumper, stock looking mufflers in stock location , straight thru ok , X pipe ok No idea what the grids are but they are allowed to run a digital type ignition with a stock looking dist housing. Compression there is no limit Rear suspension is factory stock style leafs and a race shock , no caltrac type , no slapper bars No ring pack rules, there is a cubic inch limit on big blocks , not sure what it is on a smallblock ? Roller cams allowed , aftermarket rockers allowed but they need to fit under a stock type valvecover 2 gaskets , no spacers ... the valvecover rule does not apply to the BBC, they can run an aftermerket that is MUCH taller , no one makes one for other makes ? Thanks. I know something cam up the up the other day that I think a 1/2 inch wider wheel was allowed which would help with the footprint. I’m assuming a 904 with lite weight parts are allowed also.
#3187606
10/30/23 11:55 AM
10/30/23 11:55 AM
Posts: 4,610 Motor City
6PKRTSE
Motor City
The F.A.S.T class is awesome. One of my favorite classes of racing. All of these cars are impressive.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3187608
10/30/23 12:06 PM
10/30/23 12:06 PM
Posts: 20,222 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The F.A.S.T class is awesome. One of my favorite classes of racing. All of these cars are impressive. I read the rules and there are a lot of “grey” areas that you would have to learn and push to the limits. Are they allowed and do they shave their tires. Living close to Lernerville dirt track I know those guys have lots of tire tricks.
#3187613
10/30/23 12:26 PM
10/30/23 12:26 PM
Posts: 4,801 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Forums have the most knowledgeable members. But Face Book Groups have taken over. The FB Groups have NON knowledgeable members. I was reading the comments of this Duster on the FBG. The majority simply does not understand- "Factory Appearing Stock Tire." Many members dumbfounded and naysaying that a stock Duster 340 is so fast. It's not stock. Only thing stock is the appearance. That's the point. Gotta select a car and available drivetrain that will lend itself to heavy modifications internally to make BIG power. That's why the Hemi did so well in this class. Factory high flow heads- great induction and great flowing exh manifolds.
Keep old mopars alive.
#3187634
10/30/23 01:28 PM
10/30/23 01:28 PM
Posts: 4,734 Wichita
GY3
Wichita
The F.A.S.T class is awesome. One of my favorite classes of racing. All of these cars are impressive. I read the rules and there are a lot of “grey” areas that you would have to learn and push to the limits. Are they allowed and do they shave their tires. Living close to Lernerville dirt track I know those guys have lots of tire tricks. The consensus among those that have experimented with them is that they work best when shaved down to the wear bars and have minimal tread showing. No chemicals added.
