Re: Harmonic balancer speedi sleeves
[Re: jwb123]
#3187577
10/30/23 10:14 AM
10/30/23 10:14 AM
Posts: 10,831 North Dakota
6PakBee
North Dakota
Maybe I'm misunderstanding what I am seeing but I'd swear that a sleeve on a balancer wears a groove faster than the balancer itself.
[Re: rickraw]
#3187832
10/31/23 12:06 PM
10/31/23 12:06 PM
Posts: 20,263 Park Forest, IL
slantzilla
Park Forest, IL
I have a damper from Damper Doctors that came back with a sleeve on it. I've had it on a couple motors and there's no wear on the sleeve yet, but it's drag race only.
[Re: Neil]
#3187847
10/31/23 01:00 PM
10/31/23 01:00 PM
Posts: 1,548 Seattle, WA
375inStroke
Special needs person
Seattle, WA
SS is harder than cast steel or cast iron that most balancers are made of so it should last much longer or maybe even forever? I'm sure cast iron is harder than stainless, and has better wear properties.
[Re: 375inStroke]
#3187852
10/31/23 01:27 PM
10/31/23 01:27 PM
Posts: 19,878 north of coder
moparx
SS is harder than cast steel or cast iron that most balancers are made of so it should last much longer or maybe even forever? I'm sure cast iron is harder than stainless, and has better wear properties. it all depends on the grade of stainless or cast iron the item is made out of. having machined all grades of both over my 45+ working career, i have run into cast iron that was so hard it was a real task to find the right cutting insert grade to plow through it. and although stainless grades can be super tough as well, i have cut several grades of it as though it was made of butter. just my personal life experiences as a machinist. your mileage will vary. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: Neil]
#3188336
11/02/23 06:28 PM
11/02/23 06:28 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
speedy sleeves are soft. If they were hard they would split when being stretched onto the parent part. If you had cast material as thin as a speedy sleeve, it would split as soon as you started to press it on.
