Re: Dipstick hardened material / Need to drill
[Re: TJP]
#3187497
10/29/23 10:01 PM
10/29/23 10:01 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Me personally I would mill it with a carbide end mill. But short of that, a carbide drill if its really tough, but at minimum cobalt drill. If I am drilling stainless, cobalt drills are where I start.
[Re: markz528]
#3187537
10/30/23 04:27 AM
10/30/23 04:27 AM
Posts: 21,508 N.E. OHIO, USA
A12
N.E. OHIO, USA
Me personally I would mill it with a carbide end mill. But short of that, a carbide drill if its really tough, but at minimum cobalt drill. If I am drilling stainless, cobalt drills are where I start. Start with the smallest drill bit possible and work up in small increments.
[Re: BDW]
#3187548
10/30/23 07:35 AM
10/30/23 07:35 AM
Posts: 1,335 Oregon
earlymopar
"Nitrates" are food preservatives. "Nitriding" is a hardening process involving nitrogen and is typically used on drills and end mills. Mark is spot-on in his reply and suggestions.
"I tried several different bits, the titanium with nitrate coated, but they break before doing anything."
[Re: moparx]
#3187746
10/30/23 09:56 PM
10/30/23 09:56 PM
Posts: 15,358 Omaha Ne
TJP
Omaha Ne
make sure you drill is not in reverse.................. [ask my brother about that, and he says bad words...... ] Years ago i took my freshly sharpened drill bit set to a buddy's house to help him work on is car. After a few minutes he says these bits are a dull as a flat nosed punch. I wander over and said they are right hand drill bits he says HUH? I said if you want to drill holes with the direction your drill motor is turning you'll need LEFT had drill bits. He asked what do my hands have to do with it? He never did live that one down 🤪🤣🤣 Right up there with my ex dip💩 employee that installed a brand new Bi metal bandsaw blade stating It was a POS and I got ripped off as it was dull. Helps to install the blade with the teeth the right direction.😉 They walk amongst us 🤪🤪🍻
[Re: TJP]
#3187790
10/31/23 08:35 AM
10/31/23 08:35 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
make sure you drill is not in reverse.................. [ask my brother about that, and he says bad words...... ] Years ago i took my freshly sharpened drill bit set to a buddy's house to help him work on is car. After a few minutes he says these bits are a dull as a flat nosed punch. I wander over and said they are right hand drill bits he says HUH? I said if you want to drill holes with the direction your drill motor is turning you'll need LEFT had drill bits. He asked what do my hands have to do with it? He never did live that one down 🤪🤣🤣.😉 They walk amongst us 🤪🤪🍻 I agree, but.... Everyone needs a set of left hand drill bits. I heard for years from old timers how left hand were handy for removing broken off right hand thread bolts but held off buying myself a set. When I finally did and had an occasion to try them, the old timers were right! I also learned if you had a small battery hammer drill, very briefly engaging the hammer function helps in removals using left hand bits. I have several types of extractor sets, all have strengths and weaknesses. Have you heard NASA is in a “stuck screw pickle“ on their asteroid sample container? Kicker is it is inside a super secure glove box, two screws stuck out of 32 ( in the 1990s I had to mill flat rare earth carbide samples inside a dry nitrogen glove box so I feel their pain) https://bobistheoilguy.com/forums/threads/nasa-cant-get-two-screws-out.375262/https://wonderfulengineering.com/nasa-is-reportedly-struggling-to-open-its-asteroid-container/
