78 Lean Burn computer question #3186768
10/27/23 09:04 AM
10/27/23 09:04 AM
md
mopars4ever Offline OP
md
I have a 78 360 lean burn volare with a 4091732 spark control computer. I was looking to carry a spare computer just in case. I can`t find that part number. Will another part number for a 78 360 lean burn work? I am wondering how interchangeable they may be. Trying to keep the lean burn system original.
Re: 78 Lean Burn computer question [Re: mopars4ever] #3186773
10/27/23 09:37 AM
10/27/23 09:37 AM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Hope this helps a little. It's a page from the 1993 Mopar supersession book where it shows the 15 part numbers that supersede to and from the number you supplied. There is an arrow pointing to the supplied number.
Re: 78 Lean Burn computer question [Re: twodoorpost] #3186777
10/27/23 09:51 AM
10/27/23 09:51 AM
Tony440 Offline
Tony440  Offline
This is a great list. I have an original survivor 1977 Cordoba with 13K miles. I too am looking for a spare spark control computer to keep on hand . The part no. on my computer is 4091440. I don't see it on this list.
Re: 78 Lean Burn computer question [Re: twodoorpost] #3186785
10/27/23 10:16 AM
10/27/23 10:16 AM
Tony440 Offline
Tony440  Offline
Thanks for posting this list. Is there another page more part numbers. Like I mentioned below I need to know what part number replaces 4091440 which is marked on my original spark control computer. Here is a picture of the part no. on my computer. It doesn't seem to be on the list. Thanks again.
Re: 78 Lean Burn computer question [Re: Tony440] #3186854
10/27/23 02:39 PM
10/27/23 02:39 PM
md
md
Thank you for the list.
Re: 78 Lean Burn computer question [Re: Tony440] #3186861
10/27/23 03:03 PM
10/27/23 03:03 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Just google your number.
Re: 78 Lean Burn computer question [Re: NITROUSN] #3186887
10/27/23 05:37 PM
10/27/23 05:37 PM
md
md
ok I found that 4106068 and 4106086 will interchange 4091732 ,Thanks all
Re: 78 Lean Burn computer question [Re: mopars4ever] #3187150
10/28/23 07:13 PM
10/28/23 07:13 PM
md
md
Found one NOS in a sealed box . Thanks to all that helped.
Re: 78 Lean Burn computer question [Re: mopars4ever] #3187314
10/29/23 11:20 AM
10/29/23 11:20 AM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Here's the list for 4091440
Re: 78 Lean Burn computer question [Re: mopars4ever] #3187329
10/29/23 12:32 PM
10/29/23 12:32 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Glad you found the part.
Do any of those replacement part numbers alter the air to fuel ratio to make the engine run smoother than the Chrysler original?
Have a vented distributor cap:
https://www.cartalk.com/content/i-bought-new-chrysler-cordoba-lean
I wonder if modern Irridium tip spark plugs would help?
I have often wondered how lean a a/f mixture
a modern twin spark plug variable valve timing 5.7 V8 could get to
with an aftermarket EFI like the Megasquirt.
At the Australian Autospeed website years ago there was a review of an Australian spec Honda Insight that leaned its gasoline engine highway cruise air to fuel ratio out to 25 to 1, and the liters per 100 kilometer dash display got above the equivalent of 60 miles per USA gallon.
I cannot find a link to the article through Google search
but all the Autospeed articles are in the Wayback machine of the Internet Archive.
Of course 50 to 1 air to fuel ratios used to be common at highway cruise on 1980s American diesel pickups.
https://www.sae.org/publications/technical-papers/content/880291/
You can still legally do lean burn in the USA on natural gas generators, with the economics favorable around 2000 hours of operation per year:
https://www.generac.com/Industrial/GeneracCorporate/media/Library/email/Rich-Burn_FactSheet.pdf
Detonation danger goes down at very lean mixtures.
At 23 to 1 air to fuel, compression ratios of 15 can be used, says German test engine results:
https://www.sae.org/publications/technical-papers/content/2021-24-0034/
Re: 78 Lean Burn computer question [Re: 360view] #3187366
10/29/23 01:50 PM
10/29/23 01:50 PM
md
md
Good question, It kinda makes me wonder if they did make changes with every new superseded part number.
Re: 78 Lean Burn computer question [Re: mopars4ever] #3187392
10/29/23 02:54 PM
10/29/23 02:54 PM
USA
3
360view Offline
360view  Offline
3
USA
I have 2 of these KAL 2969 spark analyzers and have found them useful.
https://www.ebay.com/itm/3052253888...DjXYqPdGJ2AlKLQNy%7Ctkp%3ABk9SR8DckcvvYg
They clip around a ignition wire and give continuous digital readouts for an individual cylinder of:
peak kilovolts (what it takes to jump the gap and begin the spark)
burn kilovolts ( lesser amount of kilovolts to continue the spark)
burn time (thousandths of a second the spark endures)
These numbers can be used to tell whether a cylinder mixture is rich or lean,
and whether compression in that cylinder is good or poor.
Such a meter and readouts might be useful on a lean burn system
I am attaching two photos from the KAL 2969 manual pages that explain this ( hope they are in focus good enough to read)
Re: 78 Lean Burn computer question [Re: 360view] #3187466
10/29/23 06:25 PM
10/29/23 06:25 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
My lean burn on my 78 fury is going where it belongs. In the trash.
Re: 78 Lean Burn computer question [Re: twodoorpost] #3187588
10/30/23 10:41 AM
10/30/23 10:41 AM
Tony440 Offline
Tony440  Offline
Thank you so much.
Re: 78 Lean Burn computer question [Re: twodoorpost] #3187589
10/30/23 10:42 AM
10/30/23 10:42 AM
Tony440 Offline
Tony440  Offline
Thanks to everyone for the help.
Re: 78 Lean Burn computer question [Re: Tony440] #3191255
11/15/23 09:24 PM
11/15/23 09:24 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
You can buy any number and it'll work, but make sure yours has only one set of plugs, some later ones had 2 plugins.
Leanburns had their issues, but I have 2 of my 4 Magnums still using them.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
