valve body iid #3186729
10/26/23 10:03 PM
10/26/23 10:03 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
got this valve body with numbers on top plate ?
PAS 17680 04003 did not see this pn on t a websight ?
anyone know this brand
suppose to be a manual shift
trans was a mess rear support all galled up
rear springs rollers ,, cage tore up also
might have been from being towed a fair distance at some point ?
Re: valve body iid [Re: calrobb2000] #3186749
10/26/23 11:32 PM
10/26/23 11:32 PM
A727Tflite Offline
A727Tflite  Offline
17680 on the cover is likely a Turbo Action manual shift valve body.
Re: valve body iid [Re: A727Tflite] #3186750
10/26/23 11:35 PM
10/26/23 11:35 PM
A727Tflite Offline
A727Tflite  Offline
Here is the info on said part number.
Re: valve body iid [Re: A727Tflite] #3186800
10/27/23 11:34 AM
10/27/23 11:34 AM
Loudoun County, VA
Brad_Haak Online content
Brad_Haak  Online Content
Loudoun County, VA
If this is the FMVB w/o low-band apply, then that's the one I run FWIW
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
