Contact TCP Global @ TCPglobal.com Go to the restoration shop tab....... and then the auto color library to pick your color. Message me if you need additional help.
For the correct acrylic laquer finish noted below:
Restoration Shop (AL) Acrylic Lacquer Paint System
AL is a Professional Easy-To-Use Single-Stage Gloss Paint Coating System that is Designed for Automotive Refinishing and Restoration Purposes but is also used for Guitar and Furniture Refinishing. AL provides a long-lasting lacquer finish result that can be polished to a very high gloss. For additional color depth and extra protection for a show quality finish, AL can be clear-coated with CL3245 High-Performance Lacquer Clear (Not included, but available separately).
AL has a 1 to 1 mixing ratio, 1 part AL Paint Color to 1 part of Medium or Slow Drying Thinner
The required Medium and Slow Drying Thinners are Available Separately or in Kits along with Acrylic Lacquer Paint Color.
Use LT70 Medium Thinner for 70-85° F or LT85 High Gloss Slow Thinner for 85° F and above
The correct color code for 1972 Dart = Black 9392
link
