PS box q
#3185902
10/23/23 12:31 PM
10/23/23 12:31 PM
Posts: 630 Ct
Wirenut
Ct
Hi all I have a 65 b body with PS . Guy near me has a firm feel box for sale that he had in a 73 E body . Other than changing the pitman arm , will this fit my car ?
Re: PS box q
[Re: Wirenut]
#3185988
10/23/23 05:18 PM
10/23/23 05:18 PM
Posts: 5,818 ohio
ruderunner
ohio
Might have to change the fittings but otherwise yes.
Angry white pureblood male
Re: PS box q
[Re: ruderunner]
#3186083
10/24/23 04:47 AM
10/24/23 04:47 AM
Posts: 630 Ct
Wirenut
Ct
Might have to change the fittings but otherwise yes. Thanks so much
Re: PS box q
[Re: Wirenut]
#3186132
10/24/23 10:11 AM
10/24/23 10:11 AM
Posts: 528 SW CO
HemiSportFury
SW CO
Make sure you get your pitman arm situation figured out first. Later PS boxes had a larger diameter shaft and early pitman arms do not fit.This can be a challenge with an early b-body. If it's the smaller shaft you're good.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: PS box q
[Re: HemiSportFury]
#3186329
10/25/23 06:15 AM
10/25/23 06:15 AM
Posts: 630 Ct
Wirenut
Ct
Make sure you get your pitman arm situation figured out first. Later PS boxes had a larger diameter shaft and early pitman arms do not fit.This can be a challenge with an early b-body. If it's the smaller shaft you're good. Any advice on what pitman might work?
Re: PS box q
[Re: Wirenut]
#3186399
10/25/23 12:36 PM
10/25/23 12:36 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Make sure you get your pitman arm situation figured out first. Later PS boxes had a larger diameter shaft and early pitman arms do not fit.This can be a challenge with an early b-body. If it's the smaller shaft you're good. Any advice on what pitman might work? I put a cop box in my 68 Satellite and the suggested part per mopar action ( i believe) was for a 73 B body.
Re: PS box q
[Re: Wirenut]
#3186541
10/25/23 09:21 PM
10/25/23 09:21 PM
Posts: 528 SW CO
HemiSportFury
SW CO
Make sure you get your pitman arm situation figured out first. Later PS boxes had a larger diameter shaft and early pitman arms do not fit.This can be a challenge with an early b-body. If it's the smaller shaft you're good. Any advice on what pitman might work? If the new box has a small spline, same as you have now you're good. Use it. If it's the bigger spline then the problems begin. The pitman arm and idler arm need to match (same length and pitch) and your 65 uses a stud mount idler so later through bolt idler arms will not work. So your best bet is to make sure the splines match. Sorry I can't be of more help.
Re: PS box q
[Re: HemiSportFury]
#3186587
10/26/23 08:40 AM
10/26/23 08:40 AM
Posts: 630 Ct
Wirenut
Ct
Make sure you get your pitman arm situation figured out first. Later PS boxes had a larger diameter shaft and early pitman arms do not fit.This can be a challenge with an early b-body. If it's the smaller shaft you're good. Any advice on what pitman might work? If the new box has a small spline, same as you have now you're good. Use it. If it's the bigger spline then the problems begin. The pitman arm and idler arm need to match (same length and pitch) and your 65 uses a stud mount idler so later through bolt idler arms will not work. So your best bet is to make sure the splines match. Sorry I can't be of more help. Thanks . Yes new box is large shaft. Will call firm feel .
