Engine Oil Retention Device…… #3185766
10/22/23 06:28 PM
10/22/23 06:28 PM
Heaven
EvilB1Dart Offline OP
Heaven
While doing some small maintenance on the car and oil change I figured I’d snap a few pics of mine since a few people have asked. A buddy of mine built it out of aluminum. It fits perfect and snug underneath with a small gap below the oil pan. It has two holes drilled through the AlterKtion in front and two rear tab-brackets attached to the midplate. When mounted it’s about 1” above the frame-saver skis. Nice clean setup easy to install/remove.
"Any fool can know. The point is to understand"
- A. Einstein
Re: OIL RETENTION DEVICE……. [Re: EvilB1Dart] #3185767
10/22/23 06:29 PM
10/22/23 06:29 PM
Heaven
Heaven
One more
- A. Einstein
Re: OIL RETENTION DEVICE……. [Re: EvilB1Dart] #3185772
10/22/23 06:53 PM
10/22/23 06:53 PM
Chesterfield Twp. Mi.
John Burdine Offline
Looks good Wes.
Re: OIL RETENTION DEVICE……. [Re: John Burdine] #3185898
10/23/23 12:24 PM
10/23/23 12:24 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Looks good. I need to make one this winter for my car. Tired of putting my engine diaper on for the strip and taking it back off for the street. Retains too much heat on those extremely hot summer days. Besides melting excess strape material on the headers gets old.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: OIL RETENTION DEVICE……. [Re: 6PKRTSE] #3185901
10/23/23 12:30 PM
10/23/23 12:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looks good. We will be in your neck of the woods testing on the 10th with the red car. Be great to see you out there
Re: Engine Oil Retention Device…… [Re: EvilB1Dart] #3185979
10/23/23 04:41 PM
10/23/23 04:41 PM
montana
BANDIT Offline
BANDIT  Offline
montana
A little off topic, but, what have you got planned for that PG sitting behind the hoist leg????
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: OIL RETENTION DEVICE……. [Re: John Burdine] #3185987
10/23/23 05:16 PM
10/23/23 05:16 PM
Heaven
Heaven
Originally Posted by John Burdine
Looks good Wes.
Thanks John.
- A. Einstein
Re: OIL RETENTION DEVICE……. [Re: 6PKRTSE] #3185989
10/23/23 05:22 PM
10/23/23 05:22 PM
Heaven
Heaven
Thanks. I was going to run a custom blanket but chose not to in the end. I’m happy with this setup. Hope I never need it to do its job LOL
- A. Einstein
Re: OIL RETENTION DEVICE……. [Re: Al_Alguire] #3185990
10/23/23 05:23 PM
10/23/23 05:23 PM
Heaven
Heaven
Thanks Al. On the calendar. I’ll come check you guys out.
- A. Einstein
Re: Engine Oil Retention Device…… [Re: BANDIT] #3185991
10/23/23 05:26 PM
10/23/23 05:26 PM
Heaven
Heaven
That is a spare Glide I’ve had. It’s now going to find its way into my kids car being built by Comp Chassis.
- A. Einstein
Re: Engine Oil Retention Device…… [Re: EvilB1Dart] #3186035
10/23/23 08:18 PM
10/23/23 08:18 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
That Fox Body is on point ! !
Good luck , looks like a top notch ride !! up
....BAD A$$ STREET CAR.....
Re: Engine Oil Retention Device…… [Re: n20mstr] #3186055
10/23/23 09:57 PM
10/23/23 09:57 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
what if anything are you using to absorb oil ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Engine Oil Retention Device…… [Re: n20mstr] #3186067
10/23/23 11:10 PM
10/23/23 11:10 PM
Heaven
Heaven
Thanks. It will be nice when it’s done. Mike at Comp Chassis always does an excellent job. Still a ways to go. Motor should be done soon.
- A. Einstein
Re: Engine Oil Retention Device…… [Re: tex013] #3186068
10/23/23 11:16 PM
10/23/23 11:16 PM
Heaven
Heaven
Tex
Phelps 1” F3 Oil Retaining Felt on the interior of the pan.
- A. Einstein
Re: Engine Oil Retention Device…… [Re: EvilB1Dart] #3186219
10/24/23 04:36 PM
10/24/23 04:36 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Tex
Tex
New best MPH 130.32
