Engine Oil Retention Device……
#3185766
10/22/23 06:28 PM
10/22/23 06:28 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
While doing some small maintenance on the car and oil change I figured I’d snap a few pics of mine since a few people have asked. A buddy of mine built it out of aluminum. It fits perfect and snug underneath with a small gap below the oil pan. It has two holes drilled through the AlterKtion in front and two rear tab-brackets attached to the midplate. When mounted it’s about 1” above the frame-saver skis. Nice clean setup easy to install/remove.
"Any fool can know. The point is to understand"
- A. Einstein
Re: OIL RETENTION DEVICE…….
[Re: John Burdine]
#3185898
10/23/23 12:24 PM
10/23/23 12:24 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
Looks good. I need to make one this winter for my car. Tired of putting my engine diaper on for the strip and taking it back off for the street. Retains too much heat on those extremely hot summer days. Besides melting excess strape material on the headers gets old.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3185901
10/23/23 12:30 PM
10/23/23 12:30 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Looks good. We will be in your neck of the woods testing on the 10th with the red car. Be great to see you out there
Re: Engine Oil Retention Device……
[Re: EvilB1Dart]
#3185979
10/23/23 04:41 PM
10/23/23 04:41 PM
Posts: 422 montana
BANDIT
montana
A little off topic, but, what have you got planned for that PG sitting behind the hoist leg????
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: 6PKRTSE]
#3185989
10/23/23 05:22 PM
10/23/23 05:22 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Looks good. I need to make one this winter for my car. Tired of putting my engine diaper on for the strip and taking it back off for the street. Retains too much heat on those extremely hot summer days. Besides melting excess strape material on the headers gets old. Thanks. I was going to run a custom blanket but chose not to in the end. I’m happy with this setup. Hope I never need it to do its job LOL
- A. Einstein
[Re: Al_Alguire]
#3185990
10/23/23 05:23 PM
10/23/23 05:23 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Looks good. We will be in your neck of the woods testing on the 10th with the red car. Be great to see you out there Thanks Al. On the calendar. I’ll come check you guys out.
- A. Einstein
[Re: BANDIT]
#3185991
10/23/23 05:26 PM
10/23/23 05:26 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
A little off topic, but, what have you got planned for that PG sitting behind the hoist leg???? That is a spare Glide I’ve had. It’s now going to find its way into my kids car being built by Comp Chassis.
- A. Einstein
[Re: EvilB1Dart]
#3186035
10/23/23 08:18 PM
10/23/23 08:18 PM
Posts: 4,696 On the parachute mount
n20mstr
A little off topic, but, what have you got planned for that PG sitting behind the hoist leg???? That is a spare Glide I’ve had. It’s now going to find its way into my kids car being built by Comp Chassis. That Fox Body is on point ! ! Good luck , looks like a top notch ride !!
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3186055
10/23/23 09:57 PM
10/23/23 09:57 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
what if anything are you using to absorb oil ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: n20mstr]
#3186067
10/23/23 11:10 PM
10/23/23 11:10 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
A little off topic, but, what have you got planned for that PG sitting behind the hoist leg???? That is a spare Glide I’ve had. It’s now going to find its way into my kids car being built by Comp Chassis. That Fox Body is on point ! ! Good luck , looks like a top notch ride !! Thanks. It will be nice when it’s done. Mike at Comp Chassis always does an excellent job. Still a ways to go. Motor should be done soon.
- A. Einstein
[Re: tex013]
#3186068
10/23/23 11:16 PM
10/23/23 11:16 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Tex Phelps 1” F3 Oil Retaining Felt on the interior of the pan.
- A. Einstein
[Re: EvilB1Dart]
#3186219
10/24/23 04:36 PM
10/24/23 04:36 PM
tex013
Sydney,Australia
Tex Phelps 1” F3 Oil Retaining Felt on the interior of the pan. Thanks Tex
