Re: Abs problem on 07 1500
[Re: fastmark]
#3186262
10/24/23 08:01 PM
10/24/23 08:01 PM
Posts: 5,812 ohio
ruderunner
ohio
Contaminated fluid is a thing and checking the cap seal is a valid inspection.
Trapped air is also a thing. A scan tool that can cycle the abs valves is useful. Or, panic stops on a loose surface to force the abs to cycle.
Angry white pureblood male
[Re: ruderunner]
#3186277
10/24/23 08:47 PM
10/24/23 08:47 PM
Posts: 4,945 WI
Dcuda69
WI
Trapped air is also a thing. A scan tool that can cycle the abs valves is useful. Or, panic stops on a loose surface to force the abs to cycle. Yep^^^ and Yep^^^
