Re: Best bit, tool and or method for spot weld removal?
[Re: A12]
#3185210
10/20/23 08:28 AM
10/20/23 08:28 AM
Posts: 12,078 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
An air chisel with a flat paddle blade is the quickest way I have found. Of course, it destroys one panel and has to have plenty of room for access. But it can be a time and patience saver where and when it can be used.
Other than that, I use a good drill bit as often as not. I have the blunt bit spot weld bits and the toothed bits, too. Each has their place, and each has their issues. The biggest issue is to start the bit precisely in the center of the spot. There usually is enough deformation in the center to throw the start off. That leaves strong attachment around an edge that has to chiselled or ground into submission. No one I have ever tried is the best in all possible circumstances. And all of the high quality ones are really expensive. The drill bits may be your best and only choice to reach a long way.
Master, again and still
[Re: DaveRS23]
#3185213
10/20/23 08:45 AM
10/20/23 08:45 AM
Posts: 8,265 fredericksburg,va
cudaman1969
fredericksburg,va
I allways use the cutter type (tiny hole saw) with the spring point. I replace the point with a shortened 6d nail then drill dead center (3/32nds drill bit) of the spot so the nail stays centered. If you need tool longer use a socket and extension, 1/4” stuff works good, a little silicone holds it together. If you need the cut hole solid again use a roofing nail to weld it up, grind flat and just like new again
[Re: cudaman1969]
#3185227
10/20/23 09:52 AM
10/20/23 09:52 AM
Posts: 10,714 North Dakota
6PakBee
North Dakota
Just did this on a Bronco windshield hinge. I have a set of spotweld cutters This One but after about three of them, just got a 3/8 drill bit and cut the rest out (about 25) in less time than it took for the first three. It really depends on how nice a job you are trying to do and what you are trying to save, the top layer or the bottom layer.
[Re: 6PakBee]
#3185242
10/20/23 10:35 AM
10/20/23 10:35 AM
Posts: 43,547 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Blair Rotabroach is what I have always used...
JB Rhinehart, Realist
A-Body's RULE!
