Page 3 of 3 1 2 3
Re: Oiling Issue - Won’t Hold Prime [Re: Cab_Burge] #3183771
10/13/23 09:18 PM
10/13/23 09:18 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Oiling Issue - Won’t Hold Prime [Re: Cab_Burge] #3184521
10/17/23 05:24 AM
10/17/23 05:24 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Originally Posted by Cab_Burge
I think the hose liner, neoprene, rubber or Teflon may have something to do with this issue.
I now use Teflon lined hose only on both oil systems and fuel systems, no other type of liner up work
All the major brands of hoses say that the Teflon line will hose take a lot more pressure and heat than the other types of hose liner due safely work scope twocents
They are stiffer and hold their shape around corners making them a little harder to work with, but they last forever, unlike some of the other type of liners shruggy scope
I try to use the curved hose fittings on the ends that need it instead of the sharp turn hose ends twocents scope
I agree with the teflon lined hose, working with suction and heat you don't want the hose collapsing in on itself.
Re: Oiling Issue - Won’t Hold Prime [Re: 451Mopar] #3184722
10/17/23 11:13 PM
10/17/23 11:13 PM
On a side note the small block drivers side head oils when the dampener is at 20 ATDC #6 compression and the passenger head oils when the dampener is 90 degrees (1/4 turn) or 5.693" around the dampener BTDC #1 compression and a big block oils when #6 and #8 are at TDC compression (I forget which head is which). With cam/lifter failures being what they are I like to minimize cranking.
Re: Oiling Issue - Won’t Hold Prime [Re: RapidRobert] #3192298
11/20/23 09:31 PM
11/20/23 09:31 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Got the engine on the run stand and it did take 3-4 seconds for it to build pressure, so I have decided to go ahead and install a check valve. Did a quick fit up tonight and wanted some feedback on the routing-just curious about the two 90 degree bends.
'75 Plymouth Duster
Page 3 of 3 1 2 3
