Another 727 question #3184318
10/16/23 09:13 AM
10/16/23 09:13 AM
tboomer Offline OP
tboomer  Offline OP
Should a 727 transmission be drained warm or cold? I am getting ready to install my new pan....If it warms up!! wrench
Re: Another 727 question [Re: tboomer] #3184338
10/16/23 10:11 AM
10/16/23 10:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you want warm/hot oil dripping all over you ?
Do it cold , if it doesn't have a drain plug on the convertor take the front external cooler line off at the trans and let it drain.
Re: Another 727 question [Re: tboomer] #3184361
10/16/23 12:23 PM
10/16/23 12:23 PM
IMGTX Offline
IMGTX  Offline
Since you are removing/replacing the pan. If it doesn't have a magnet I would add one.
They won't save a bad transmission but hey are a great help in letting you know the internal wear when you remove the pan next time.
A drain plug in the pan is nice also. less mess when draining or changing fluid.
Re: Another 727 question [Re: IMGTX] #3184387
10/16/23 02:18 PM
10/16/23 02:18 PM
tboomer Offline OP
tboomer  Offline OP
I have it off guys and will let it drain for a while. Thanks everyone! wave
