Re: School me on a transbrake
[Re: Kam*Kuda]
#3184588
10/17/23 12:17 PM
10/17/23 12:17 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
[[ [/b]b][/[b]b]quote=W.I.N. Racing]Things to investigate - Converter anti ballooning plate. 👍 - a bleed hole in the front Drum (facilitates quicker releases) I assume this can be done when the brake is installed? Nope, Need to disassemble the trans Drill the drum. - Good quick release Brake Button do you normally put this on the steering wheel? I normally do but to each their own... - Transmission shield👍 - Sprag (doesn't have to be a bolt in but make sure its in perfect condition)👍 - Move Vent front Pump cover to tail housing. will need to check - Good front yoke - Front Planetary set - likes to rip out the spline. no idea… any more details on this ? Typically the planet cage is made from aluminum, I used to rip them out 30 yrs ago when raced with 727's. They were not designed for the abuse they are given in race applications...There are Steel alternatives Thats my [/quote]
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: 71Demon528]
#3184590
10/17/23 12:22 PM
10/17/23 12:22 PM
Posts: 1,030 ohio
67mprfan
ohio
I second what everyone says.
As far as a button goes, I have mine on the steering wheel, but know others prefer it mounted elsewhere away from the wheel.
I 3rd on all the recommendations. Also with the transbrake, I believe most requires you to hold the button to use reverse So if may make driving on the street a pain
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: Cab_Burge]
#3184612
10/17/23 01:50 PM
10/17/23 01:50 PM
Posts: 2,924 A shed in England
Tig
A shed in England
It's the other way round, street gears are hard tempered and brittle. Pro gears are soft and wear out quick. https://www.dragzine.com/news/do-you-need-street-gears-or-pro-gears/
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: BANDIT]
#3185582
10/21/23 08:43 PM
10/21/23 08:43 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
Would I benefit from a transbrake?
I currently leave off idle. I push through my brakes too easily
It is a Procharger car on I have zero boost at idle and I assume I could bring up the rpm’s with a brake
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Kam*Kuda]
#3185678
10/22/23 11:28 AM
10/22/23 11:28 AM
Posts: 138 Connellsville
71Demon528
Connellsville
Only one way to find out
[Re: Kam*Kuda]
#3185691
10/22/23 12:26 PM
10/22/23 12:26 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
Looks like you need a looser converter by looking at your 60ft . , then see what a trans brake would do, your ET is WAY better than what your 60ft shows.
[Re: CSK]
#3187935
10/31/23 09:56 PM
10/31/23 09:56 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
Looks like you need a looser converter by looking at your 60ft . , then see what a trans brake would do, your ET is WAY better than what your 60ft shows. The yellow line is the rpm The blue line is the throttle This is how I launch off idle Any thoughts on the converter ?
