Re: I Have No Power From a Stop
[Re: B1MAXX]
#3184303
10/16/23 08:32 AM
10/16/23 08:32 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
try more initial timing. If that helps, change the curve.
[Re: VITC_GTX]
#3184339
10/16/23 10:12 AM
10/16/23 10:12 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
All good questions.
It has the Summit electronic ignition/dizzy. The timing is about 12 degrees to keep it at ~34 total. Vacuum is hooked up to ported vacuum. No other know issues.
Once it get's going it accelerates OK. 34 total , that's not enough , bring it up to 38 , listen for pinging .
[Re: JohnRR]
#3184392
10/16/23 03:00 PM
10/16/23 03:00 PM
Posts: 10,208 Someplace you aren't
SomeCarGuy
All good questions.
Once it get's going it accelerates OK. 34 total , that's not enough , bring it up to 38 , listen for pinging . 34 is enough. Stock heads like 33-35 for max power per Mopar Action. My own experience has been 34 is what they like. Certainly that is enough timing to make good power taking off. 38 might’ve been good with old high octane gas at every station, but not these days.
I want my fair share
[Re: VITC_GTX]
#3184440
10/16/23 07:18 PM
10/16/23 07:18 PM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
The Road Runner is on the lift so I went out and checked the clutch linkage.
I did not have the 5/32" free play at the end of the clutch fork as recommended by the FSM, I had little to no free play. I don't think the rod was adjusted long enough to put pressure on the fingers/pressure plate that would cause any issues, but stranger things have happened.
[Re: VITC_GTX]
#3184445
10/16/23 07:33 PM
10/16/23 07:33 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
This is my only 4 speed car so I don't have much to compare it to but this can't be right. What are your thoughts???
I have, and have had, multiple 4 speed vehicles. This is confusing. Is it a steel flywheel? Maybe increase the idle speed. Try an initial timing of 15 degrees plus your ported vacuum advance.
[Re: BSB67]
#3184482
10/16/23 10:34 PM
10/16/23 10:34 PM
VITC_GTX
I have, and have had, multiple 4 speed vehicles. This is confusing. Is it a steel flywheel? Maybe increase the idle speed. Try an initial timing of 15 degrees plus your ported vacuum advance. Sorry, this is my only 4 spd car, I do have three CJ-5's and have had 4 spd trucks but of course they are/were geared lower. Yep, steel flywheel. I'll push the timing up a bit and see what that does for me. Thanks.
[Re: TJP]
#3184507
10/17/23 12:54 AM
10/17/23 12:54 AM
SomeCarGuy
I did not have the 5/32" free play at the end of the clutch fork as recommended by the FSM, I had little to no free play. I don't think the rod was adjusted long enough to put pressure on the fingers/pressure plate that would cause any issues, but stranger things have happened. based on the above statement and your previous one about the clutch engaging at the top is cause for concern . The clutch should start to engage about 1-1.5" or so off the floor and have free play at the top before feeling the resistance of the pressure plate. This was my concern based on what was posted.
