RB con rod small end spec ? #3183956
10/14/23 05:03 PM
10/14/23 05:03 PM
Suburb of Chicago, IL
BCFKody Offline OP
BCFKody  Offline OP
Looking for the blueprint spec for stock big block connecting rods small end for pressed pin. One of our former Presidents said “Trust but verify.” I’m thinking about buying some aftermarket stock replacement rods with cap screw big ends (nice) and pressed pin small ends for stock or stock type forged 6 pack pistons. I’ve heard there have been some failures with these rods related to pin walk destroying the cylinder wall due to the small end being out of spec (too large) for a pressed pin. If I decide to buy these rods, I want to verify the small end is right,. If not, I ‘l’ll send them back to China. Thanks!
Re: RB con rod small end spec ? [Re: BCFKody] #3184042
10/15/23 03:27 AM
10/15/23 03:27 AM
1.09??? scope
Re: RB con rod small end spec ? [Re: BCFKody] #3184047
10/15/23 06:26 AM
10/15/23 06:26 AM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
As per service manual 1.0923 - 1.0928
Re: RB con rod small end spec ? [Re: varunner] #3184058
10/15/23 08:21 AM
10/15/23 08:21 AM
BCFKody Offline OP
BCFKody  Offline OP
Thanks Virginia Runner! Best of luck.
