Re: How do I know if my Cone Suregrip is good
[Re: BPBP440]
#3183450
10/12/23 06:53 PM
10/12/23 06:53 PM
Posts: 12,189 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Don't tear it down. You can use your axles to test it.
Clamp one axle in a good vice. Slide the Sure Grip on and then the other axle. Use a good sized pry bar between the lug studs to see how hard it is to turn the axle. Seems like the manual calls for 100lb break away. If that's not right, someone will correct it.
And if it is not tight, don't trash it. I have fixed quite a few of them over the years even though a lot of guys say they are junk and cannot be fixed.
Master, again and still
[Re: DaveRS23]
#3183457
10/12/23 07:11 PM
10/12/23 07:11 PM
Posts: 264 Farmington Hills, MI
BPBP440
And if it is not tight, don't trash it. I have fixed quite a few of them over the years even though a lot of guys say they are junk and cannot be fixed. I’ll do that. Maybe a plate with the same hole pattern as the studs and a nut welded in the middle could allow me to use a torque wrench for breakaway.
[Re: BPBP440]
#3183463
10/12/23 07:19 PM
10/12/23 07:19 PM
Posts: 21,835 Kirkland, Washington
Pacnorthcuda
And if it is not tight, don't trash it. I have fixed quite a few of them over the years even though a lot of guys say they are junk and cannot be fixed. I’ll do that. Maybe a plate with the same hole pattern as the studs and a nut welded in the middle could allow me to use a torque wrench for breakaway. Just bolt a wheel/tire on the axle that’s not in the vice. The old shade tree test was if you can turn the tire with your arms the sure grip is shot. Then you disassemble and resurface (belt sander) the cones, but that’s a different discussion.
[Re: Pacnorthcuda]
#3183485
10/12/23 08:42 PM
10/12/23 08:42 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
And if it is not tight, don't trash it. I have fixed quite a few of them over the years even though a lot of guys say they are junk and cannot be fixed. I’ll do that. Maybe a plate with the same hole pattern as the studs and a nut welded in the middle could allow me to use a torque wrench for breakaway. You can just use a lug nut. 100lbs is not too much for them. Just bolt a wheel/tire on the axle that’s not in the vice. The only down side to that is the weight. Getting kinda heavy out there with one end in a vice. The old shade tree test was if you can turn the tire with your arms the sure grip is shot. Then you disassemble and resurface (belt sander) the cones, but that’s a different discussion. Yep, .030" to .050" off the small ends of the cones makes it almost as good as new. Such as that is.
[Re: BPBP440]
#3183614
10/13/23 12:42 PM
10/13/23 12:42 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
And if it is not tight, don't trash it. I have fixed quite a few of them over the years even though a lot of guys say they are junk and cannot be fixed. I’ll do that. Maybe a plate with the same hole pattern as the studs and a nut welded in the middle could allow me to use a torque wrench for breakaway. Here's an old pair of axle stubs that I machined so a torque wrench reading could be taken in a vise. If the cones need to be machined, Doc Diff has spacer shims to take up the distance. https://www.doctordiff.com/8-3-4-cone-sure-grip-shim-pack.html
[Re: BPBP440]
#3183634
10/13/23 01:40 PM
10/13/23 01:40 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
It was garabge when it was designed, and still is. The reason one would machine the cones and add shims is because it disintegrates every time you turn, sending little pieces of metal into the gear oil that gets run thru the gear teeth and bearings.Save yourself the headaches down the road , you're almost all the way there, toss it in your scrap bin..
[Re: BPBP440]
#3183644
10/13/23 02:20 PM
10/13/23 02:20 PM
Posts: 4,692 Wichita
GY3
Wichita
No cone sure-grip is any good when you apply power and traction!
I didn't pay attention to JohnRR years ago and junked a brand new Mancini built 742 cased 3rd member after just one season of hard use.
~$1,300.00 in the garbage.
Dana 60 and spool for the win.
[Re: GY3]
#3183661
10/13/23 03:04 PM
10/13/23 03:04 PM
Posts: 6,291 nowhere
Sniper
nowhere
Dana 60 and spool for the win. It's like buying a Mack truck to pick up eggs at the grocery store. Yeah, it could do that but over kill. Dana 60 and a spool is not for the same application a cone suregrip was designed for, no wonder it failed.
[Re: John_Kunkel]
#3183784
10/13/23 11:10 PM
10/13/23 11:10 PM
BPBP440
And if it is not tight, don't trash it. I have fixed quite a few of them over the years even though a lot of guys say they are junk and cannot be fixed. I’ll do that. Maybe a plate with the same hole pattern as the studs and a nut welded in the middle could allow me to use a torque wrench for breakaway. Here's an old pair of axle stubs that I machined so a torque wrench reading could be taken in a vise. If the cones need to be machined, Doc Diff has spacer shims to take up the distance. https://www.doctordiff.com/8-3-4-cone-sure-grip-shim-pack.html . That is a slick set-up!
[Re: BPBP440]
#3183865
10/14/23 11:49 AM
10/14/23 11:49 AM
Posts: 1,001 rust belt
Moparite
rust belt
It was garabge when it was designed, and still is. I'm not a fan of them either but used em. I would take it apart and look at the condition of the cones. There may be debris or wear. You can grind down any imperfections and get a little more time out of it before it gets worse. If you don't already have one get a magnetic drain/fill plug, It will catch any metallic debris and help keep it out of the cones.
[Re: Moparite]
#3183887
10/14/23 12:38 PM
10/14/23 12:38 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
It was garabge when it was designed, and still is. . If you don't already have one get a magnetic drain/fill plug, It will catch any metallic debris and help keep it out of the cones. I have glue strong magnets in the housings to catch debris in one of my old drag race cars that I would swap the third members around for different race tracks at higher elevations, I would wipe it cleans each time I had the third member out the reason for gluing them it was Murphy
[Re: Cab_Burge]
#3184336
10/16/23 10:06 AM
10/16/23 10:06 AM
JohnRR
U.S.S.A.
It was garabge when it was designed, and still is. . If you don't already have one get a magnetic drain/fill plug, It will catch any metallic debris and help keep it out of the cones. I have glue strong magnets in the housings to catch debris in one of my old drag race cars that I would swap the third members around for different race tracks at higher elevations, I would wipe it cleans each time I had the third member out the reason for gluing them it was Murphy I have done the same thing.
