Re: Is there a bolt on hub assembly ..... [Re: QuickDodge] #3216524
02/27/24 04:42 AM
02/27/24 04:42 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
IIRC '84 or '85 was the only year with small bolt pattern and larger outer(?) bearing of the trucks that followed.That rotor/hub should be a bolt-on for your truck.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: Is there a bolt on hub assembly ..... [Re: Cheeto] #3219687
03/11/24 10:16 AM
03/11/24 10:16 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
I bought set rotors for a 82. Put new bearings 8n. Bolted right on
So now front has a 4.5 bolt pattern
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
