Accumlator in Torqueflites
#3182895
10/10/23 09:07 PM
10/10/23 09:07 PM
Posts: 6,147 Melbourne , Australia
LA360
Can someone explain what the accumulator in a Torqueflite does?
When we change over to a manual valve body, we put a blocking rod behind the piston to stop it moving. If you were doing a case from scratch, could you just do away with the piston and bore in the case?
Unless I read the wrong sections, I didn't find much of an explanation in the Monroe book.
Thanks in advance
Cheers
Alan Jones
Re: Accumlator in Torqueflites
[Re: LA360]
#3182982
10/11/23 08:50 AM
10/11/23 08:50 AM
Posts: 1,147 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Here's a thread I started a few years ago trying to understand what the accumulator does: https://board.moparts.org/ubbthread...me-to-fluid-flow-schematics-for-727.html
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: LA360]
#3183052
10/11/23 12:48 PM
10/11/23 12:48 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you were doing a case from scratch, could you just do away with the piston and bore in the case? Yes. Many current race VB's effectively eliminate the accumulator by blocking all of the fluid passages to it.
[Re: fbs63]
#3183185
10/11/23 06:46 PM
10/11/23 06:46 PM
LA360
Please tell me you are making an SFI approved case! A friend has asked me to do a billet A727 case for him. I wish I had the time to, but I don't see it happening any time soon. If I was to do a case for myself, it would be a 904 or Proflite type case anyway. Rumour has it that A&A are doing a billet A727 SFI case, are they going to PRI this year? That should be pretty cool if it happens,
Alan Jones
