Drag car height #3182671
10/10/23 08:58 AM
10/10/23 08:58 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Curious if a glide is physically smaller than a 727. I have a BBM Duster, and want to lower it some, but the deep 727 trans pan actually hangs down some. Wondering how everyone gets their car so low....
Re: Drag car height [Re: Dragula] #3182674
10/10/23 09:14 AM
10/10/23 09:14 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If the trans pan is below your headers I think that is an issue. The headers are the lowest point on my car. I run a moroso aluminum trans pan and it is not the lowest point under my car. It allows me to hold about 8-9 qts of trans fluid and that seems to be plenty for my application.
68 Barracuda Formula S 340
Re: Drag car height [Re: Bad340fish] #3182676
10/10/23 09:31 AM
10/10/23 09:31 AM
Dragula Offline OP
Dragula  Offline OP
Headers are above the wheel spindles.....lol
Re: Drag car height [Re: Dragula] #3182710
10/10/23 11:40 AM
10/10/23 11:40 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Lowest point are my custom headers, sitting at exactly 2 inches. That’s with an aluminum deep dish pan on a 727.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Drag car height [Re: BloFish] #3182720
10/10/23 12:04 PM
10/10/23 12:04 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I run a cast deep pan on a turbo 400, what helped a lot was to mill the cooling ribs off it. Right now i have about 3.5" to the trans pan, but the rear of my oil pan is 2.75" . But im not driving anywhere except in the trailer and to the lanes at the track.
You still have stock suspension up front? you can put a fairly tall aftermarket urethane snubber in the lower arm. Trim it that it only has 1/4 to an 1/8 clearance at rest, this way you know the car wont "bottom out" and your limiting the down travel in the front suspension.
....BAD A$$ STREET CAR.....
Re: Drag car height [Re: Dragula] #3182752
10/10/23 01:30 PM
10/10/23 01:30 PM
Cab_Burge Online work
Cab_Burge  Online Work
How about using some spacers between the trans mount and the transmission tail shaft mount work scope twocents
Re: Drag car height [Re: Cab_Burge] #3182772
10/10/23 02:28 PM
10/10/23 02:28 PM
Dragula Offline OP
Dragula  Offline OP
I have Magnum Force front end on it, and its lowered a little already,
Trans is right up against the floor with the shield htting
Re: Drag car height [Re: Cab_Burge] #3182786
10/10/23 02:51 PM
10/10/23 02:51 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
My car sits as low as I can get it with a stock driveshaft tunnel, and front frame rails. The lower control arms are almost touching the bump stops that have been cut down a inch. My scattershield is one of the lowest parts of the car, other than the headers, and 4 link crossmember.
69 GTX 68 Road Runner
Re: Drag car height [Re: JERICOGTX] #3182907
10/10/23 09:27 PM
10/10/23 09:27 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine sits low and my deep trans pan as low as my headers also. However it is still several inches from the ground. If you want to increase your ground clearance just put a standard pan back on it and run a large cooler.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Drag car height [Re: 6PKRTSE] #3182955
10/11/23 05:36 AM
10/11/23 05:36 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Are you running the B&M deep pan? If so, they're deep pans, more for a truck. I'm running the TCI deep pan, two inches higher & I run -8 lines to & from a big cooler to add fluid volume. 6k converter & can hot lap no problems.
