Re: Drag car height
[Re: Dragula]
#3182674
10/10/23 09:14 AM
10/10/23 09:14 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
If the trans pan is below your headers I think that is an issue. The headers are the lowest point on my car. I run a moroso aluminum trans pan and it is not the lowest point under my car. It allows me to hold about 8-9 qts of trans fluid and that seems to be plenty for my application.
68 Barracuda Formula S 340
Re: Drag car height
[Re: Dragula]
#3182710
10/10/23 11:40 AM
10/10/23 11:40 AM
Posts: 16,493 On the run…
BloFish
On the run…
Lowest point are my custom headers, sitting at exactly 2 inches. That’s with an aluminum deep dish pan on a 727.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: Drag car height
[Re: BloFish]
#3182720
10/10/23 12:04 PM
10/10/23 12:04 PM
Posts: 4,688 On the parachute mount
n20mstr
I run a cast deep pan on a turbo 400, what helped a lot was to mill the cooling ribs off it. Right now i have about 3.5" to the trans pan, but the rear of my oil pan is 2.75" . But im not driving anywhere except in the trailer and to the lanes at the track.
You still have stock suspension up front? you can put a fairly tall aftermarket urethane snubber in the lower arm. Trim it that it only has 1/4 to an 1/8 clearance at rest, this way you know the car wont "bottom out" and your limiting the down travel in the front suspension.
....BAD A$$ STREET CAR.....
Re: Drag car height
[Re: Cab_Burge]
#3182786
10/10/23 02:51 PM
10/10/23 02:51 PM
Posts: 10,038 MN
JERICOGTX
MN
My car sits as low as I can get it with a stock driveshaft tunnel, and front frame rails. The lower control arms are almost touching the bump stops that have been cut down a inch. My scattershield is one of the lowest parts of the car, other than the headers, and 4 link crossmember.
69 GTX
68 Road Runner
Re: Drag car height
[Re: JERICOGTX]
#3182907
10/10/23 09:27 PM
10/10/23 09:27 PM
Posts: 4,571 Motor City
6PKRTSE
Motor City
Mine sits low and my deep trans pan as low as my headers also. However it is still several inches from the ground. If you want to increase your ground clearance just put a standard pan back on it and run a large cooler.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
