color temperature / garage lighting #3181695
10/06/23 01:54 PM
10/06/23 01:54 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I'm finally building a garage and I'm looking at LED lighting. I'm curious what everyone uses/prefers for garage lighting color temperature. My existing garage has 4100k T12 bulbs and the color is white to my eyes when the bulbs are new. However they dim and turn more yellow as they age. I'm finding it difficult to find affordable LED fixtures in 4100k. Most new integrated LED fixtures are 6500k which is way too blue for my liking. I have found a few that advertise as being 5000k. If I already had a bunch of 4' fluorescent fixtures I could easily buy LED replacement bulbs in 4100k but I don't.
Looking online I get more confused than when I started. I think every manufacture has their own idea of what "warm white", "soft white", "bright white" and "daylight" are. One article I read said that 4000-4500k is good for a garage but then said 5000k is the norm for showrooms and when you will be doing detailed work.
The article also said that paint looks the best at 5000ish color temp. I went to the local big box store and had a look at their lighting display. One fixture toggled back and forth between 3000/4000/5000k. The 4000 looks best to me but maybe in an automotive garage setting 5000k would be acceptable. Just curious what everyone prefers. Thanks
Re: color temperature / garage lighting [Re: burdar] #3181702
10/06/23 02:07 PM
10/06/23 02:07 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
My eyes are old.
When I updated the lighting in my garage a couple of years back I went with 4, 4' 5000k led tubes. What a remarkable improvement, originally had 2 100w incandescent bulbs, lol.
You may be able to go to a good hardware store and check out the colors at the lighting display.
Re: color temperature / garage lighting [Re: Sniper] #3181708
10/06/23 02:30 PM
10/06/23 02:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I bought the 4' LEDs from Harbor Freight - $19 each on sale - a couple years ago, and they were a huge improvement over the double 4' fluorescents I had.
I beleive they're 5000.
Much brighter with half the bulbs. Just plug in & voila !
Re: color temperature / garage lighting [Re: topside] #3181742
10/06/23 05:34 PM
10/06/23 05:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I like 5000 to 5600. Bright but not glaring and everything stays it's normal color whch is great if you are doing any wiring.
Re: color temperature / garage lighting [Re: stumpy] #3181749
10/06/23 06:12 PM
10/06/23 06:12 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You can't have "too much" light. And ideally - IMHO - you want that as close to "daylight" as possible. That said, I still have florecents in my shop and all the bulbs are labelled "daylight".
Re: color temperature / garage lighting [Re: Stanton] #3181752
10/06/23 07:09 PM
10/06/23 07:09 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I agree.
Human eyes function best in bright light. The job requiring the brightest light is brain surgery. That says it all for me.
5000K is the best color temp for any work environment, IMO.
Re: color temperature / garage lighting [Re: jcc] #3181777
10/06/23 08:47 PM
10/06/23 08:47 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I buy 4100k T8s. 96 bulbs in my main shop. To me they are pretty white. I won’t go any higher.
Re: color temperature / garage lighting [Re: Pacnorthcuda] #3181791
10/06/23 09:46 PM
10/06/23 09:46 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
I updated a few yeas back to double (string?) LED fixtures. The ones I bought are adjustable with dip switches. They're set on Daylight which I think is 6500? Not sure but I need to tone them down as my eyes start watering after ~ 8 hours. Eye drops help but I just need to find the time to dim them down a bit as I am concerned about the long term effects. When I had fluorescent I always went with daylight bulbs and was fine. But the LED's seem to have a different idea on what daylight is IMO.
I have another post going on monitors due to the brightness of one. Just swapped it out an hour or so ago and OMG what a difference. beer
Re: color temperature / garage lighting [Re: TJP] #3181840
10/07/23 06:58 AM
10/07/23 06:58 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
After trying a couple different bulbs these have met my needs. Have them in the garages and my work shed.
Re: color temperature / garage lighting [Re: J_BODY] #3181849
10/07/23 08:24 AM
10/07/23 08:24 AM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
What I would add is that you also need to look at lumen output when choosing a fixture or bulb. My garage has 4’ Florescent fixtures. I looked into replacing the tubes with the led tubes and discovered that they were not as bright as a t8 5k fluorescent tube.
Also . Led sounds great , but they often fail sooner than a fluorescent. Keep in mind they are just cheap junk from CHINA . At least with a fluorescent you can replace tubes or ballast easily and inexpensively .
T5 fluorescent are even brighter.
Re: color temperature / garage lighting [Re: Wirenut] #3181857
10/07/23 08:58 AM
10/07/23 08:58 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I used 5000k LED's. This is what that looks like.
Re: color temperature / garage lighting [Re: Wirenut] #3181859
10/07/23 09:05 AM
10/07/23 09:05 AM
The Garden State
LimelightCuda Offline
The Garden State
I had fluorescent in my garage and I replaced them with LEDs from Home Depot. I used the kind with the LEDs built in to the fixture and thankfully i haven't had any failures yet but if I do I will have to replace the entire fixture. This was about 5 years ago so I don't even know if they still sell the same exact fixtures I bought. Next time would definitely get LED fixtures with replaceable lights.
The reason I went with LEDs was because I live in the northeast and in the winter the fluorescent lamps took about 20 to 25 minutes to start lighting up. Unfortunately, my garage is not insulated and the fluorescent lamps don't do very well in the cold.
I used the highest K rating I could find at the time. I think they were 4100K. If I were doing it today I would go with 5000K.
Phil
1970 Barracuda Gran Coupe
1970 A66 Challenger Convertible
Re: color temperature / garage lighting [Re: 6PakBee] #3181863
10/07/23 09:22 AM
10/07/23 09:22 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Having the walls and ceiling white really helps too.
Re: color temperature / garage lighting [Re: Sniper] #3181878
10/07/23 10:48 AM
10/07/23 10:48 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
iagree
Although white is not IMO real practical for a garage floor, I use light grey.
Re: color temperature / garage lighting [Re: jcc] #3181906
10/07/23 12:13 PM
10/07/23 12:13 PM
moparx Offline
moparx  Offline
i went with 5000k units when i replaced all the lighting in the garage.
12, four foot lights in a 28x32 space really light up the place ! biggrin
beer
Re: color temperature / garage lighting [Re: moparx] #3181921
10/07/23 12:44 PM
10/07/23 12:44 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I bought some 5K led bulbs from Lowes a few years ago, Best investment i ever made. Don't remember the brand but i kept the box because i will be using them again. It's awesome when it's cold out and you turn on the lights and bam, Instant light compared to waiting 20 minuets for florescent lights to warm up.
Re: color temperature / garage lighting [Re: LimelightCuda] #3182068
10/07/23 10:20 PM
10/07/23 10:20 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Looking at the bulb pricing vs built in I don't see an advantage price wise or am I missing something ??? shruggy beer
Re: color temperature / garage lighting [Re: burdar] #3182093
10/08/23 06:24 AM
10/08/23 06:24 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I like the 5000K light during the day.
At the other extreme, I use pure green LED light only for middle of the night bathroom visits.
It makes a difference in getting back to sleep.
Re: color temperature / garage lighting [Re: 360view] #3182120
10/08/23 11:03 AM
10/08/23 11:03 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
If you are installing lighting you can get a permanent style. If you already have florescent fixtures just get bulbs.
Re: color temperature / garage lighting [Re: Moparite] #3182130
10/08/23 11:43 AM
10/08/23 11:43 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Using LED bulbs in typical T8 fixtures means(?) the transformers are still in the circuit, and if so, seems to me that negates some of the power/heat/reliability savings LED's are intended to provide.
