440 into a '64 318 drivetrain? #3181031
10/04/23 04:51 PM
10/04/23 04:51 PM
Sour Lake, Texas
61-63 Offline OP
61-63  Offline OP
Sour Lake, Texas
Is swapping a 440 automatic block into a '64 318 full size car a doable thing? Is the 727 trans the same etc., etc.
Re: 440 into a '64 318 drivetrain? [Re: 61-63] #3181047
10/04/23 05:21 PM
10/04/23 05:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Trans is different you’ll need a 361-383-426 trans (cable shift) unless using a floor shifter, you’ll need the steel engine mounts for the engine. IF it has a 727, (more than likely) driveshaft will work. Very easy swap
Re: 440 into a '64 318 drivetrain? [Re: cudaman1969] #3181190
10/04/23 11:05 PM
10/04/23 11:05 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have the trans and driveshaft, The valve body is for a console shift but I likely have the rooster comb and manual valve if needed. PM me if interested smile
Re: 440 into a '64 318 drivetrain? [Re: TJP] #3181231
10/05/23 07:06 AM
10/05/23 07:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The only part of the trans that needs to be swapped is the case. We have plenty of big block 64 cases. easy swap.
Doug
Re: 440 into a '64 318 drivetrain? [Re: dvw] #3181298
10/05/23 10:59 AM
10/05/23 10:59 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
When you say "full size" are you referring to a B-body?
'63 Dodge 330
11.19 @ 121 mph
Re: 440 into a '64 318 drivetrain? [Re: GY3] #3181324
10/05/23 12:18 PM
10/05/23 12:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Full Size" refers to what we commonly call a C-body...in '64 that would be an 880. These cars use a unique engine mount.
http://imperialservices.net/Cparts.html
Re: 440 into a '64 318 drivetrain? [Re: John_Kunkel] #3181337
10/05/23 12:53 PM
10/05/23 12:53 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
John, Did the 'full size "C barges" come with 318's? Can't recall ever seeing one shruggy that's likely be why we're ASSuming it's a B body beer
Re: 440 into a '64 318 drivetrain? [Re: TJP] #3181347
10/05/23 01:10 PM
10/05/23 01:10 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A poly
Re: 440 into a '64 318 drivetrain? [Re: GY3] #3181457
10/05/23 06:04 PM
10/05/23 06:04 PM
Sour Lake, Texas
61-63 Offline OP
61-63  Offline OP
Sour Lake, Texas
The car is a '64 Polara 500 with a 318, console floor shift and bucket seats.
Re: 440 into a '64 318 drivetrain? [Re: 61-63] #3181465
10/05/23 06:16 PM
10/05/23 06:16 PM
AndyF Offline
AndyF  Offline
1964 Polara 500 is basically a B body car, sometimes called an early B body. Most B body suspension parts will bolt on, some won't. Engine location is slightly different than later B body cars so you have to pay close attention to stuff like headers.
Re: 440 into a '64 318 drivetrain? [Re: 61-63] #3181490
10/05/23 07:42 PM
10/05/23 07:42 PM
A727Tflite Offline
A727Tflite  Offline
Find the correct steel engine brackets and you can reuse the isolators.
Like DVR said, change the main case and reuse all the internals of the 727, reuse the trans crossmember and mount.
Later model 67-72 exhaust manifolds fit perfectly, reuse the starter, alternator and even the converter.
Would need B/RB alternator brackets, and the correct oil pan - 62-65 B/RB engines set further forward than 66 and later.
If you use headers make sure you verify what you buy will fit the 62-65 chassis.
Re: 440 into a '64 318 drivetrain? [Re: 61-63] #3181526
10/05/23 10:07 PM
10/05/23 10:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have your trans and driveshaft. Already has the correct valve body for the console shift. might be able to find one of our transport guys going your way. Might even be able to meet them somewhere not too far away. I have no use for it. If interested PM me wink
Re: 440 into a '64 318 drivetrain? [Re: cudaman1969] #3181528
10/05/23 10:09 PM
10/05/23 10:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A poly
According to my limited research, 62 up the smallest was a 361 shruggy
Re: 440 into a '64 318 drivetrain? [Re: 61-63] #3181564
10/06/23 12:01 AM
10/06/23 12:01 AM
Cab_Burge Online work
Cab_Burge  Online Work
The 1962 to 1965 BB V8 K members put the front of the motors further forward than the 1966 to 1973 did in relation to the trans mounts and firewall sheet metal, my message is that you can either swap in a later model K member or change the oil pan so the sump won't hit the steering linkage.
I like to swap the K members myself so the cars can get better traction and handling up wrench scope That also makes the header selection better up scope
Re: 440 into a '64 318 drivetrain? [Re: TJP] #3181624
10/06/23 10:32 AM
10/06/23 10:32 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
John, Did the 'full size "C barges" come with 318's? Can't recall ever seeing one shruggy that's likely be why we're ASSuming it's a B body beer [/quote]
A poly [/quote]
According to my limited research, 62 up the smallest was a 361 shruggy [/quote]
He said 318 that’s why I said a poly. LA 318s came out in 67 I think. If he has the 361 nothing needs changing
Re: 440 into a '64 318 drivetrain? [Re: cudaman1969] #3181631
10/06/23 10:51 AM
10/06/23 10:51 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
v-8 K-frames from '63-'65 are all the same save for the Hemi K.
Very easy to swap in the engine with the right brackets. A guy named William Cowger used to have the brackets and hardware for this but I've lost his information.
I chose to keep the early K-frame in my car to use all stock components and make getting to the bellhousing bolts easy and maybe bolt on a crossram after I'm tired of going fast. grin
78030 Hedman headers work really well on this combo if you are so inclined.
'63 Dodge 330
11.19 @ 121 mph
Re: 440 into a '64 318 drivetrain? [Re: cudaman1969] #3181813
10/06/23 11:29 PM
10/06/23 11:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A poly [/quote]
He said 318 that’s why I said a poly. LA 318s came out in 67 I think. If he has the 361 nothing needs changing [/quote]
I believe the 62 up poly's were 318's Correct me if I'm wrong on that beer
Re: 440 into a '64 318 drivetrain? [Re: TJP] #3181908
10/07/23 12:19 PM
10/07/23 12:19 PM
moparx Offline
moparx  Offline
i believe you are correct; 318 poly motor 62-66 in the states, 67 in canada.
beer
