Re: Electric winch issues
[Re: Cab_Burge]
#3180824
10/04/23 05:43 AM
10/04/23 05:43 AM
Posts: 5,815 ohio
ruderunner
ohio
Sounds like it has a circuit breaker in it. Maybe getting weak.
Angry white pureblood male
[Re: ruderunner]
#3180827
10/04/23 06:15 AM
10/04/23 06:15 AM
Posts: 6,246 nowhere
Sniper
nowhere
Sounds like it has a circuit breaker in it. Maybe getting weak. Or a thermal overload switch, which is similar, lol.
[Re: Rhinodart]
#3180861
10/04/23 09:25 AM
10/04/23 09:25 AM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
My Harbor Freight 9500 lb electric winch has worked fine for a couple of years. Lately it has had issues, when using it to pull a vehicle on the trailer it will work for a few seconds then stop. Each time I wait about 3-5 seconds and it will work again for a few seconds, It will pull the vehicle on the trailer but takes much longer of course. The last 5 vehicles it has done this. I checked and cleaned all the connections to no avail. Could it be one of the relay's? If so, how to test? Does it have a circuit breaker? If your batteries are getting weak the voltage might be dropping enough to cause the amps to go up and trip the breaker, after a short time it resets. Just a thought.
68 Barracuda Formula S 340
[Re: mopars4ever]
#3180863
10/04/23 09:25 AM
10/04/23 09:25 AM
Posts: 10,714 North Dakota
6PakBee
North Dakota
Have you called them? They have a number for technical questions on that winch, 1-888-866-5797.
[Re: 6PakBee]
#3180880
10/04/23 10:04 AM
10/04/23 10:04 AM
Posts: 43,544 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
This is my 12th winch over the last 30 years, I know they only last so long and it doesn't seem to matter how much you pay for them. I will try the above replies and see what happens. It has a wireless remote, I have never changed the battery in that, don't if that causes intermittent issues...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3180906
10/04/23 11:41 AM
10/04/23 11:41 AM
Posts: 3,884 Oregon
hooziewhatsit
My HF 3500lb did the same thing when I used a dead battery with it. I presume the voltage dropped enough under load that the winch cut out. Even with no weight on it, it would cut out.
Charged the battery for 10 minutes after I got back home, and it wound itself back up without issue.
[Re: Rhinodart]
#3180908
10/04/23 11:46 AM
10/04/23 11:46 AM
Posts: 19,402 north of coder
moparx
you may be on to something with the remote. my wife's car was acting up with the key fob. sometimes the door locks would work, sometimes not. multiple pushes on the button usually worked, however. changed the battery in it and all was well.
[Re: topside]
#3181091
10/04/23 07:58 PM
10/04/23 07:58 PM
Rhinodart
Rhinotruck
Rhinotruck
Does the winch motor get really hot ?
Only 2 winch problems I've had - and that sound you hear is me knocking on wood - is a bad connection at the handheld trigger for my trailer winch, and what I guess was water seepage into the winch motor used on my snow plow. The plow motor went intermittent and quickly just quit - I merely replaced it, wasn't expensive. I wrapped electrical tap around the seam of the plow winch and it's been fine since. Motor does not get hot. I tried it again today and the battery was dead. Will charge the bejesus out of it this weekend and see if that helps, although I kjnow it had a good charge the last time it was doing this...
A-Body's RULE!
[Re: Rhinodart]
#3181120
10/04/23 08:40 PM
10/04/23 08:40 PM
Posts: 10,559 Freeport IL USA
poorboy
Freeport IL USA
We ran a cheap winch on our old race car trailer. Most of the problems we had with it were nearly always a battery issue. Car batteries used for running a winch often only last 2-3 years. The low voltage in the battery kicks out the resets on the winch motors.
If your winch motor is not getting hot, the problem is likely not a winch problem but a wiring or battery issue. The battery for the remote would be the 1st thing I would replace, if the sensor on the winch isn't getting the signal from the remote, its shutting off. Could be a problem with the receiving sensor as well. Then you need to have the main battery for the winch power load tested, I'm betting it fails that test, even being fully charged. We got an extra couple years out of marine deep cycle batteries. They were designed to be heavily loaded until nearly dead, then be fully charged, over and over, but that was years ago, might not be the case anymore.
[Re: poorboy]
#3181152
10/04/23 09:26 PM
10/04/23 09:26 PM
Rhinodart
Rhinotruck
Rhinotruck
If your winch motor is not getting hot, the problem is likely not a winch problem but a wiring or battery issue. The battery for the remote would be the 1st thing I would replace, if the sensor on the winch isn't getting the signal from the remote, its shutting off. Could be a problem with the receiving sensor as well. Then you need to have the main battery for the winch power load tested, I'm betting it fails that test, even being fully charged. We got an extra couple years out of marine deep cycle batteries. They were designed to be heavily loaded until nearly dead, then be fully charged, over and over, but that was years ago, might not be the case anymore. I always use Semi batteries, got them from International when I worked there. If I can't get them then I use Marine deep cycle, I have never used a car battery. It may be time to replace it again, batteries have gotten expensive since Covid...
A-Body's RULE!
[Re: d-150]
#3181192
10/04/23 11:10 PM
10/04/23 11:10 PM
Rhinodart
Rhinotruck
Rhinotruck
We r lucky Down here we can go to the u pull it pay 30 bucks a piece.look at the stickers some batteries r still in warranty I can get used car batteries here for $30 also, but they are still not good enough for a 10,000 lb winch...
A-Body's RULE!
