Emergency test alert Wednesday
#3179820
10/01/23 10:25 AM
10/01/23 10:25 AM
Posts: 12,088 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
' Get ready to not freak out. On Wednesday, October 4 at 2:20 p.m. ET, every TV, radio and cellphone in the United States should blare out the distinctive, jarring electronic warning tone of an emergency alert.
It's a test – only a test.
Officially, the trial is called the Nationwide Emergency Alert Test. You know it's a test and not an actual emergency because it's accompanied by an explanation of the test.
No, it's not a national conspiracy to infect people with nanoparticles. Yes, it does go back all the way to the Cold War in the 1950s. No, we can't play you the tone – we could get hit with a big fine if we did.
But mostly the test is an important way to make sure that if something really bad – and really big – happens, Americans can be warned quickly.
The alert will air at the same moment across every time zone in the country starting at 2:20 p.m. ET on Wednesday, Oct. 4. The time will vary across time zones, so look to see when you might be alerted.
2:20 p.m. ET 1:20 p.m. CT 12:20 p.m. MT 11:20 a.m. PDT 10:20 a.m. ADT 8:20 a.m. HST
The test is scheduled to last approximately one minute. It will only go out once, there will be no repeats. www.usatoday.com/story/news/nation/2023/10/01/emergency-alert-test-what-to-know/70981620007
Master, again and still
Re: Emergency test alert Wednesday
[Re: not_a_charger]
#3179864
10/01/23 12:47 PM
10/01/23 12:47 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
'If your phone is set to WiFi or airplane mode, it won't receive the alert because the message goes out over the cellular broadcast system.'
Maybe we need Wi-Fi or airplane mode for our 'chips?
[Re: Charger727]
#3180211
10/02/23 10:38 AM
10/02/23 10:38 AM
Posts: 28,599 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Thanks for the notice! Time to check if I have enough tin foil.... Worked almost as good at the refinery here.
[Re: poorboy]
#3180416
10/02/23 09:13 PM
10/02/23 09:13 PM
Posts: 1,117 Rochester NY
Jer
Rochester NY
I'm going to be prepared, I'm shutting my phone, TV, and radio off between noon and about 4 pm. Same..... compete power-down here. Not to sound conspiratorial, but this part had me wondering about the real reason for this 'alert': "In case the Oct. 4 test is postponed due to widespread severe weather or other significant events, the back-up testing date is Oct. 11. " Wait a minute, isn't this a test to determine the effectiveness of the two systems IN CASE OF AN EMERGENCY?? Yet bad weather will postpone the tests...... hmmmm.... never trust FEMA.
[Re: dart games]
#3180464
10/03/23 12:00 AM
10/03/23 12:00 AM
Posts: 8,396 Highland, MI.
Sunroofcuda
Highland, MI.
there saying turn off your phone.pull the battery if you can or put your phone in the micro wave.they say if you shut it off you can still recd it.is this a test to see if we turn into zombies of if they can control us.you can put it in air plane mode.something fishy about this because of fema and our goverment that i dont trust We shall see. Lots of chatter about 5G & those vaxxxxxxxxxxxxxd. If you haven't heard about this yet, you are not following the current affairs.
[Re: Jer]
#3180502
10/03/23 09:07 AM
10/03/23 09:07 AM
Posts: 3,380 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I'm going to be prepared, I'm shutting my phone, TV, and radio off between noon and about 4 pm. Same..... compete power-down here. Not to sound conspiratorial, but this part had me wondering about the real reason for this 'alert': "In case the Oct. 4 test is postponed due to widespread severe weather or other significant events, the back-up testing date is Oct. 11. " Wait a minute, isn't this a test to determine the effectiveness of the two systems IN CASE OF AN EMERGENCY?? Yet bad weather will postpone the tests...... hmmmm.... never trust FEMA. "Not to sound conspiratorial.." Proceeds to sound conspiratorial.... Cancelling drills for real-world weather events is perfectly normal. They have been testing tornado sirens around here on the first Monday of the month for the past 40 years. But if there is a chance of severe weather on the first Monday they will cancel the test so people don't confuse the test with the real thing and mistakenly ignore it. My goodness some of you guys need to put away the tin foil. What the heck is shutting off you radios going to do? Keep the mind control waves out of your cerebellum?
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
