Re: Lets see your G3 Street Strip combos and ET [Re: RTSE4ME] #3179956
10/01/23 06:37 PM
10/01/23 06:37 PM
K
Kiddart Offline
Kiddart  Offline
K
New numbers in our dart sport with my son behind the wheel, 1st pass down the track for him off the trailer was 11.35 at 120
He made a lot of passes on that tune and had a blast. Car was on a string all day.
from my dash cam
no action shots yet!!
Thank you
Kiddart
Re: Lets see your G3 Street Strip combos and ET [Re: STEFF] #3180186
10/02/23 09:25 AM
10/02/23 09:25 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by STEFF
Mine and my Son's Street/Strip cars.
My Road Runner, 3150 lbs, 425" Gen 3 Hemi, 12:1 compression, Thitek Heads, NA, Full Interior, drive it around on weekends and to work once a week, usually, pump gas on the street, MS109 at the track, best so far 9.04 @ 147, 5.73 @ 119, 1.27 60ft.
My Son's Duster, 3020 lbs, 428" Gen 3 Hemi, BGE Heads, Fogger, 12.5:1 compression, Caltracs/Sliders on rear, 26 x 8.5 Tire, Totally stock front suspension, Full Interior, drive it around on weekends and to work occasionally, pump gas on street, C23 at the track, Runs RTRA Limited Street 235 Class, best so far 5.15 @ 132, 1.15 60ft, on an .036 jet. Had an engine mishap in February at Lights Out, just got motor back together. Goal is high 4.90's. We're about 70lbs heavy for the class as well. Only need to weigh 2950. That will be rectified this off season.
[Linked Image]2023-09-20_06-53-24 by Stephen Rimay
[Linked Image]20210531_160429 by Stephen Rimay
[Linked Image]2023-09-20_07-16-46 by Stephen Rimay
[Linked Image]20221028_103913 by Stephen Rimay
[Linked Image]2023-09-20_07-13-49 by Stephen Rimay
These are incredibly impressive and makes we want to build one even more!
'63 Dodge 330
11.19 @ 121 mph
Re: Lets see your G3 Street Strip combos and ET [Re: Kiddart] #3180296
10/02/23 01:38 PM
10/02/23 01:38 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
from my dash cam
Those are some good numbers!
68 Barracuda Formula S 340
Re: Lets see your G3 Street Strip combos and ET [Re: Bad340fish] #3180674
10/03/23 06:03 PM
10/03/23 06:03 PM
K
Kiddart Offline
Kiddart  Offline
K
the numbers are ok (being modest). My Son Cameron was really hoping for it to be a flat 11.00 or a 10.99. the drag radials did the car no favors. it spun on launch and on each gear change so that was lost et and MPH. he will get it ironed out. he has ordered slicks so when they come in I can mount and balance them then back to the track. My son is very excited as this is his first engine build. he did the head and intake work. i am very happy with it for a streetcar. but my guess is my son is going to take it right back to the track and do drag and drives (I will co-pilot). Next year drag week is the goal.
he ran 93 pump gas from Sunoco
next tune is race gas tune
Car 74 dart sport
full interior
8-point roll bar
frame tied
SS springs
8 3/4 with 4.30 gears
275 drag radial
4k stall converter
904 rvmb
we guess the weight is 3200 ish maybe a little lighter (fiberglass hood)
the rest is steel.
i am learning with him on all this tuning stuff.
and when i say first pass that means first pass ever on a track!!
Thank you
Kiddart
Re: Lets see your G3 Street Strip combos and ET [Re: Kiddart] #3180841
10/04/23 08:28 AM
10/04/23 08:28 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Car 74 dart sport
full interior
8-point roll bar
frame tied
SS springs
275 drag radial
4k stall converter
904 rvmb
the rest is steel.
That is impressive for his first pass ever!
'63 Dodge 330
11.19 @ 121 mph
Re: Lets see your G3 Street Strip combos and ET [Re: Kiddart] #3207870
01/24/24 05:47 PM
01/24/24 05:47 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Car 74 dart sport
full interior
8-point roll bar
frame tied
SS springs
275 drag radial
4k stall converter
904 rvmb
the rest is steel.
GREAT first outing! What is the engine combo, if I may ask?
Re: Lets see your G3 Street Strip combos and ET [Re: aus370] #3211093
02/06/24 12:23 PM
02/06/24 12:23 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
My slow streetcar has been 5.12 to the 1/8. 3800lbs at the time. This year is 300lb lighter. This year I expect 4.90s and mid 7s in the 1/4
5.7
Stock 6.4 heads
Custom cam
Twin 7675s
Re: Lets see your G3 Street Strip combos and ET [Re: 1980volare] #3211447
02/07/24 11:47 AM
02/07/24 11:47 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
eek / up
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Lets see your G3 Street Strip combos and ET [Re: Brad_Haak] #3223337
03/28/24 12:47 PM
03/28/24 12:47 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Super SIC rides .
Re: Lets see your G3 Street Strip combos and ET [Re: Bubba] #3223996
03/31/24 01:21 PM
03/31/24 01:21 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
Stone stock ‘22 Scat Pack Charger - 12.77 @ 111 on the stock goodyear RSA 245/45/20s
