Page 2 of 3 1 2 3
Re: Oiling Issue - Won’t Hold Prime [Re: clovis] #3180164
10/02/23 08:46 AM
10/02/23 08:46 AM
PA
moparacer Offline
moparacer  Offline
PA
Originally Posted by clovis
Put the drill to it this afternoon and ran it pretty slow, I had pressure within 2-3 seconds running it slow. I went ahead and traded out the filter to a Baldwin, primed it again and will let it sit another day and try again.
What is the trick to getting the intermediate shaft in place? Seems like everytime to go install it, I spend 20 minutes slowing turning the oil pump shaft then dropping in the intermediate shaft only to find I am one tooth off one way or the other. It is like the intermediate shaft doesn’t engage the pump until the shaft is already engaged with the cam thus if the hex isn’t lined up it will not fall the rest of the way in.
Is yours a Milodon gear?
If so I have the same problem. Other pump shafts I have used never did that.
I even radiused the bottom of the teeth on the drive slightly with a flat file and it didn't help. Another PITA.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Oiling Issue - Won’t Hold Prime [Re: moparacer] #3180181
10/02/23 09:17 AM
10/02/23 09:17 AM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
It is the Milodon intermediate shaft, you have to use their slightly (and I mean slightly) longer $200 shaft with that particular pump. I have filed down the edges on the intermediate a bit to no avail. I actually keep a socket and breaker bar on the crank so I can just barely bump it to see if the shaft will fall into place, it really requires two sets of hands. It truly acts like it only has one position that it will fit, so you have to have the gear in exactly the right place-maybe I'm not holding my mouth right. Cab-I am using a longer hex shaft so I can turn the pump gear. I was going to spin it over with the starter yesterday but after 30 minutes trying to get the intermediate shaft in and lined up, I just gave up and spun it with the drill. I have tried to look at everything when it does fall in so I can repeat the sequence but it never seems to work the same way twice.
Same here, I have never had the problem on any other build, but I will say that once it is in, there is very very little slop and I do like that. On my last motor the timing seemed to move around a bit when checking it, and I am now thinking between a little slop in the chain and the intermediate shaft that may have been my issue.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Oiling Issue - Won’t Hold Prime [Re: clovis] #3180269
10/02/23 12:36 PM
10/02/23 12:36 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I've fought that problem before. The cam gear has 18 teeth. The intermediate shaft has 6 flats. What is going to happen if you try to move the intermediate shaft 1 tooth? You guessed it, now it doesn't line up with the 6 flats. The easiest way to do it is to loosen the 4 bolts holding the oil pump on and pull it away from the block, now put the shaft wherever you want, then twist the oil pump to line up on the flats and tighten the oil pump bolts back up.
2011 Drag Pak Challenger
Re: Oiling Issue - Won’t Hold Prime [Re: clovis] #3180293
10/02/23 01:21 PM
10/02/23 01:21 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’m pretty sure that with an OE pump and shaft/gear, the hex of the shaft has engaged with the pump before the gear engages with the cam.
Re: Oiling Issue - Won’t Hold Prime [Re: fast68plymouth] #3180339
10/02/23 04:10 PM
10/02/23 04:10 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree I’ve never had trouble getting the pump drive hex to engage with the pump then cam gear, though I’ve never used the Milodon external line setup
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Oiling Issue - Won’t Hold Prime [Re: scottk] #3180948
10/04/23 01:01 PM
10/04/23 01:01 PM
moparx Offline
moparx  Offline
Re: Oiling Issue - Won’t Hold Prime [Re: moparx] #3181792
10/06/23 10:00 PM
10/06/23 10:00 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
I let is sit for two days primed with the Baldwin filter. The first video is trying to prime it with just the starter, which is never does. The second video is after I pulled the distributor and hit it full tilt with the drill (600 rpms). It seems to take 3-4 second for it to build pressure.
https://youtu.be/9Upv_pIEdDs?feature=shared
https://youtube.com/shorts/SODsGh2JH3I?feature=shared
I have the check valve in hand, so do I need to go ahead and install the check valve or is the 3-4 seconds an acceptable situation?
As a side note, I also found a better way to get the intermediate shaft in and lined up easier, all I did was cut a bigger chamfer on the end of the intermediate shaft. Once I lined up the pump, I could then get the shaft to slide in much easier.
'75 Plymouth Duster
Re: Oiling Issue - Won’t Hold Prime [Re: clovis] #3181830
10/07/23 02:44 AM
10/07/23 02:44 AM
I will never use the starter motor to try and turn the motor over long enough before starting it to get oil pressure tsk
That is one of the old time Chevy racers things to do on their motors, not a good thing to try on any Mopar motors tsk down
Re: Oiling Issue - Won’t Hold Prime [Re: Cab_Burge] #3181948
10/07/23 02:12 PM
10/07/23 02:12 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Ok scrap everything I said about the additional chamfer helping in getting the gear installed. This process is extremely frustrating, i realize I can stab it and turn the distributor but the pump has to be in a certain position for it to fall in anywhere. You have to walk the shaft all the way around to see if it will fall in and when it doesn’t you slightly turn the pump and try again. I am averaging 20-30 minutes each time I do it. It seems if the shaft were just a tad longer this wouldn’t be an issue. When looking at the engagement it seems there is room for the shaft to go deeper.
Anyway, primed it this morning with the drill, installed the distributor then spun it over with the starter and it primed instantly. I started putting everything I need to start it so hopefully I will fire it tomorrow.
'75 Plymouth Duster
Re: Oiling Issue - Won’t Hold Prime [Re: clovis] #3182200
10/08/23 02:43 PM
10/08/23 02:43 PM
moparx Offline
moparx  Offline
i have primed engines with a pressure tank i built.
i fill the filter when it's installed, then fill the tank with 4-7 quarts of oil, indicated with a sight gauge/tube on the side of the tank.
the fill cap has a tire fill valve with a 1/8npt fitting in the top. i pressurize the tank to 40-45psi.
the bottom of the tank has a hose with a 1/4npt ball valve and adapter[s] that can screw into the oil pressure gauge tap. quick connect hydraulic fittings are used to keep it a no mess operation.
open the valve and "shoot" the oil into the engine, watching the sight gauge go down until the oil is almost gone, then shutting the valve while there is still some oil visible in the gauge tube.
unhook the tank, install the appropriate sending unit, and fire it up.
instant oil pressure.
just like a "home made" accusump system.
this is just my personal experience. your mileage will vary.
beer
Re: Oiling Issue - Won’t Hold Prime [Re: clovis] #3182212
10/08/23 03:32 PM
10/08/23 03:32 PM
So. Burlington, Vt.
So. Burlington, Vt.
Is the plan at this point to let the motor sit for a couple of days, then start it and see how long it takes to build pressure?
Re: Oiling Issue - Won’t Hold Prime [Re: fast68plymouth] #3182307
10/08/23 09:44 PM
10/08/23 09:44 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Kinda, I feel like at this point, anything above the starter rpm will cause it to build pressure.
I wired it and put the carb on it today, in order to start it. I spun it over a few times with the starter and it moved the gauged instantly so I felt good about starting it. First hit it back fired through the carb, so I advanced the timing a bit and hit it again. It barely fired so I hit it with a little fuel then the starter stopped engaging. I adjusted the starter position and went to start it again and then it popped the fuse from the battery to the switch. I called it a day at that point. I am assuming it is just a low voltage situation on the battery, so I will charge the battery and likely leave the charger on it the next time I go to start it.
'75 Plymouth Duster
Re: Oiling Issue - Won’t Hold Prime [Re: clovis] #3182352
10/09/23 05:06 AM
10/09/23 05:06 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Not to hijack, but I've also been fighting a "losing a prime" issue and here's what I tried to eliminate it :
i. sealed swinging pickup threads and sealed bulkhead fitting to pan side ....no go
ii. replaced pickup to pump lines ....no dice
iii. replaced fittings....nope
iv. oil line loop at pump pump inlet....nada
v. lost the swinging pickup for a fixed pickup....no change
vi. new pump....better, but still took excessive time to prime after a shutdown of 1-2 days
vii. tried different filters......same crap
Lost patience pulling the dist to prime for fireup and lucked upon this at a real good price..... laugh
Wish me luck. grin
Re: Oiling Issue - Won’t Hold Prime [Re: clovis] #3182367
10/09/23 08:42 AM
10/09/23 08:42 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have been following this post and had planned using an external oil on my 572 street Hemi. I'm now having second thoughts as i do not want those issues with priming every time i want to drive the car. Can an internal pick up be made to work with the 4.500 stroke? Is there a better external oil pan available to avoid these issues?
Re: Oiling Issue - Won’t Hold Prime [Re: LAD 524] #3182375
10/09/23 09:11 AM
10/09/23 09:11 AM
an8sec70cuda Offline
I use the old style Milodon 21815 pump w/ a stock cast iron oil pump cover b/c I hated the remote filter setup and didn't want the leak prone old style Milodon cover. I've never had an issue w/ losing prime.
Seems like this is more of an issue w/ the newer black Milodon billet pumps?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Oiling Issue - Won’t Hold Prime [Re: an8sec70cuda] #3182548
10/09/23 06:49 PM
10/09/23 06:49 PM
The first Mildon dual line external oiling system I used in 1971 worked fine up No issues ever boogie
The 2nd one had this losing prime problem down whiney shruggy
The last 5 or 6 builds using the cast Milidon aluminum oil body bodies with the nipple on the front of them work fine also up shruggy
Re: Oiling Issue - Won’t Hold Prime [Re: mopar dave] #3182665
10/10/23 08:11 AM
10/10/23 08:11 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
" I have been following this post and had planned using an external oil on my 572 street Hemi. I'm now having second thoughts as i do not want those issues with priming every time i want to drive the car. Can an internal pick up be made to work with the 4.500 stroke? Is there a better external oil pan available to avoid these issues? "
99% sure the 4.500" stroke will not work with the internal pickup.
I had enough of losing a prime so hopefully the Peterson setup will eliminate the issue. frown Being able to pre oil it before every fire up is an added bonus.
Its a PITA. confused
Some have no problem at all and other with identical components have nothing but trouble. eek
Go figure.
Re: Oiling Issue - Won’t Hold Prime [Re: LAD 524] #3182668
10/10/23 08:40 AM
10/10/23 08:40 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Ok, thanks for answering my question.
Re: Oiling Issue - Won’t Hold Prime [Re: LAD 524] #3182740
10/10/23 12:58 PM
10/10/23 12:58 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Wish me luck. grin
Chuck from BEST Machine told me about that Primer/Remote , Probably the best thing you can ever put on a BB Mopar or any engine. Get you a cheap cordless drill with a socket, run it for a minute or so. Even better is to rotate the engine while priming it . Also you really appreciate it at rebuild time because you dont have to pull the dist or anything to pre lube. All around a really great investment for your engine. NO more dry starts ever. I use it every time my car has sat for more than 24 hours
....BAD A$$ STREET CAR.....
Re: Oiling Issue - Won’t Hold Prime [Re: LAD 524] #3182745
10/10/23 01:14 PM
10/10/23 01:14 PM
I think the hose liner, neoprene, rubber or Teflon may have something to do with this issue.
I now use Teflon lined hose only on both oil systems and fuel systems, no other type of liner up work
All the major brands of hoses say that the Teflon line will hose take a lot more pressure and heat than the other types of hose liner due safely work scope twocents
They are stiffer and hold their shape around corners making them a little harder to work with, but they last forever, unlike some of the other type of liners shruggy scope
I try to use the curved hose fittings on the ends that need it instead of the sharp turn hose ends twocents scope
Page 2 of 3 1 2 3
