AFB metering rods? #3179165
09/28/23 11:10 PM
09/28/23 11:10 PM
Morgan Hill, CA
ackpht Offline OP
ackpht  Offline OP
Morgan Hill, CA
Can someone point me to a comprehensive source for metering rods? I'm not sure Edelbrock makes the sizes I'm looking for.
.068/.059
.069/.054
.0715/.058
These are for AFBs. thx
Re: AFB metering rods? [Re: ackpht] #3179187
09/29/23 04:52 AM
09/29/23 04:52 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
I will look this weekend in the secret stash. I have a LARGE collection.
Todd
Re: AFB metering rods? [Re: sasquatch] #3179712
09/30/23 10:04 PM
09/30/23 10:04 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
before Edelbrock took over, CARTER used to make "strip kits" for those. I have most of 2 of those around here. Came with an assortment of metering rods, jets, and some oversized needle and seat assemblies. those kits show up at swaps now and then.
Re: AFB metering rods? [Re: volaredon] #3179802
10/01/23 08:44 AM
10/01/23 08:44 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Edelbrock makes tuning kits too, you can even buy the rods separately if you want. Issue is, Edelbrock doesn't offer the sizes the OP wants, I looked.
Re: AFB metering rods? [Re: Sniper] #3179813
10/01/23 10:00 AM
10/01/23 10:00 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I ran into a similar issue years ago when I was trying to fine tune the AFB carbs on the Road Runner. I got the closest size over that I could and would use some sandpaper folded over and twist the rods back and forth/ and up/down with my fingers. I would check frequently with some calipers to monitor the progress and it worked out good. It is a bit time consuming, but I would just sit back in a chair and watch some TV to pass the time.
Re: AFB metering rods? [Re: 68jim] #3179819
10/01/23 10:16 AM
10/01/23 10:16 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
In my stash of rods I have two of the .0715/.058 (#16-544) those are from a Carter strip kit. I also have one of the .069/.054 (16-7057) I have another but it was worked down to a .065/.054...
Are you setting up Hemi carbs?
Re: AFB metering rods? [Re: 68jim] #3179882
10/01/23 01:50 PM
10/01/23 01:50 PM
Morgan Hill, CA
ackpht Offline OP
ackpht  Offline OP
Morgan Hill, CA
Yes. PM sent.
Re: AFB metering rods? [Re: ackpht] #3180120
10/02/23 12:45 AM
10/02/23 12:45 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
.068/.059 Close to size 0.068/0.057 Edelbrock #1417, or old Carter #16-98 (0.068/0.056")
.069/.054 The Edelbrock rods jump from 0.068 to 0.070", I don't think they list a 0.069" size? a 0.070/0.057" is #1418, and 0.070/0.052" is 1452
.0715/.058 Old Carter 0.072/0.058 is number 16-544 ( I think it was in the strip kit) Edelbrock only has one rod in the 0.071" size, 0.047" rich size, #1453. next step leaner size jumps to 0.073", and with 0.052 rich is #1457
This is part of a spreadsheet I did back around 2010, so it might be outdated?
Dosen't show the formatting, but two tables of 4 rows, left side is rods sorted by the larger "Economy" step, second table by the smaller "Power" step of the rod
SORTED BY ECONOMY STEP SORTED BY POWER STEP
LEAN RICH DIFF. REF # RICH LEAN DIFF. REF#
0.076 0.055 0.021 16-691 0.060 0.073 0.013 16-388
0.075 0.047 0.028 1459 0.058 0.072 0.014 16-544
0.075 0.042 0.033 1419 0.057 0.070 0.013 1418
0.075 0.037 0.038 1458 0.057 0.068 0.011 1417
0.073 0.060 0.013 16-388 0.057 0.065 0.008 1461
0.073 0.052 0.021 1457 0.057 0.060 0.003 1440
0.073 0.047 0.026 1456 0.056 0.068 0.013 16-98
0.073 0.042 0.031 1455 0.055 0.076 0.021 16-691
0.073 0.037 0.036 1454 0.055 0.067 0.012 1463
0.072 0.058 0.014 16-544 0.055 0.055 0.000 1436
0.071 0.047 0.024 1453 0.052 0.073 0.021 1457
0.071 0.048 0.023 16-241 0.052 0.070 0.018 1452
0.070 0.057 0.013 1418 0.052 0.068 0.016 1448
0.070 0.052 0.018 1452 0.052 0.065 0.013 16-485
0.070 0.047 0.023 1451 0.052 0.065 0.013 1460
0.070 0.042 0.028 1450 0.052 0.062 0.010 1441
0.070 0.037 0.033 1449 0.052 0.060 0.008 1439
0.068 0.057 0.011 1417 0.052 0.058 0.006 1438
0.068 0.056 0.013 16-98 0.049 0.067 0.018 1462
0.068 0.052 0.016 1448 0.049 0.057 0.008 1437
0.068 0.047 0.021 1447 0.048 0.071 0.023 16-241
0.068 0.042 0.026 1446 0.047 0.075 0.028 1459
0.067 0.055 0.012 1463 0.047 0.073 0.026 1456
0.067 0.049 0.018 1462 0.047 0.071 0.024 1453
0.065 0.057 0.008 1461 0.047 0.070 0.023 1451
0.065 0.052 0.013 16-485 0.047 0.068 0.021 1447
0.065 0.052 0.013 1460 0.047 0.065 0.018 1445
0.065 0.047 0.018 1445 0.047 0.063 0.016 1443
0.065 0.042 0.023 1416 0.042 0.075 0.033 1419
0.065 0.037 0.028 1444 0.042 0.073 0.031 1455
0.063 0.047 0.016 1443 0.042 0.070 0.028 1450
0.063 0.037 0.026 1442 0.042 0.068 0.026 1446
0.062 0.052 0.010 1441 0.042 0.065 0.023 1416
0.060 0.057 0.003 1440 0.037 0.075 0.038 1458
0.060 0.052 0.008 1439 0.037 0.073 0.036 1454
0.058 0.052 0.006 1438 0.037 0.070 0.033 1449
0.057 0.049 0.008 1437 0.037 0.065 0.028 1444
0.055 0.055 0.000 1436 0.037 0.063 0.026 1442
Re: AFB metering rods? [Re: 451Mopar] #3180200
10/02/23 10:16 AM
10/02/23 10:16 AM
VA
dragon slayer Offline
VA
Sounds like you are working on a 68 Set of Hemi carbs. The front carb .0685x.059 is 16-341. The rear carb .069x.054 is 16-543 and .0715x.058 is 16-544. Only the 544 is a common rod found in the strip kit.
Hemi rods are more unique with the length of the step and type of taper, though in weeds if you can't get original ones.
Get a 201 strip kit, it has the 16-98 which is rich on power step at .0555 and it has the 544. Having your front carb rich on power shouldn't hurt anything with the 98.
The rod stagger in the rear is a distribution issue supposedly for low speed mixture. Though I would think it effects high speed too. If you're going with a cam and raised compression of displacement, you will need to fine tune anyway.
