Re: OPENING IN BACK OF HOOD SCOOP?
[Re: jcc]
#3179516
09/30/23 09:25 AM
09/30/23 09:25 AM
Posts: 2,926 A shed in England
Tig
A shed in England
The last line says "It can improve the performance" I'm guessing the design has a lot to do with it, if this is the case. I'll be logging scoop pressure next season, interested to know if it works.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Pacnorthcuda]
#3179530
09/30/23 09:57 AM
09/30/23 09:57 AM
Posts: 22,696 Bitopia
jcc
Bitopia
ET is the definitive proof of concept. We disagree, with maybe millions of variables, it may be the final goal, but not definitive proof.
[Re: jcc]
#3179533
09/30/23 10:05 AM
09/30/23 10:05 AM
Posts: 21,835 Kirkland, Washington
Pacnorthcuda
ET is the definitive proof of concept. We disagree, with maybe millions of variables, it may be the final goal, but not definitive proof. Sure it is, just gotta hold the other variables constant, which is commonly done in drag racing.
[Re: Pacnorthcuda]
#3179536
09/30/23 10:42 AM
09/30/23 10:42 AM
jcc
Bitopia
ET is the definitive proof of concept. We disagree, with maybe millions of variables, it may be the final goal, but not definitive proof. Sure it is, just gotta hold the other variables constant, which is commonly done in drag racing. Good luck with that thought. Even in a highly "controlled" wind tunnel, they run multiple runs to find an average and account for the variables unknown or what that they can't control.
[Re: Cab_Burge]
#3179748
09/30/23 11:53 PM
09/30/23 11:53 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
In another tjought , It seems some use filters some dont , i use a screen . Would a deflecter across / in front of carb intake help , stop air straight over carb ? Or could it introduce further turbulence ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#3179861
10/01/23 12:36 PM
10/01/23 12:36 PM
jcc
Bitopia
Tex Testing likely will show what the result might be, but it will NOT tell you why something is causing the result, so many just seem to pick one and go from there.
[Re: HardcoreB]
#3180788
10/03/23 10:50 PM
10/03/23 10:50 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
I opened up the back of the scoop at the hood is really lifting and crushed the hood pin bracket and have bent the hood pins
I was amazing how high the hood bowed at the end of the quarter. About 141-142 mph
It is not enough to help the situation and I will need to do a different hood with a different scoop as the holes only partially helped
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
