Re: OPENING IN BACK OF HOOD SCOOP?
[Re: 540DUSTER]
#3178524
09/27/23 05:54 AM
09/27/23 05:54 AM
Posts: 2,937 A shed in England
Tig
A shed in England
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3178532
09/27/23 06:28 AM
09/27/23 06:28 AM
Posts: 22,732 Bitopia
jcc
Bitopia
Worthy read with a lot of repetition IMO
"Conclusion
The effects of ram air at high speeds can cause considerable boosts in power or unexpected complications. Taking into effect engine performance at higher speeds becomes complicated at times but can mean the difference between a screaming run and a surprise slump."
[Re: theraif]
#3178578
09/27/23 11:30 AM
09/27/23 11:30 AM
Tig
A shed in England
i seem to remember warren johnson quoting how much hp it took pushing a scoop through the air I wonder how much that is in comparison to how much H/P the whole frontal area of a typical door slammer type car takes ? The trade off may be worth it
[Re: Streetwize]
#3179278
09/29/23 12:56 PM
09/29/23 12:56 PM
Posts: 1,185 Loudoun County, VA
Brad_Haak
Loudoun County, VA
maybe a spring loaded flap would work well, full effect up to a certain speed and then gradual bleed off when the spring is overcome? Funny you mentioned this, cuz I was wondering if I should try something like that in my fresh-air baseplate; the new scoop is so freakin' big that it's gonna trap some serious air (second-guessing myself on having gone so much taller than original T/A)
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Neil]
#3179288
09/29/23 01:39 PM
09/29/23 01:39 PM
Tig
A shed in England
Having a big scoop and only a small air hole for the carb inlet or a smallish round air cleaner opening you may be trapping more air inside the scoop than the engine can use on the top end. That would mean that you are creating a positive pressure or a Ram Air effect, if you can tune for that you will theoretically, make more power. According to folk more experienced than I, a typical design of pro stock scoop will generate 2 psi @ 200 mph. That is 1/7 or 14% more "potential" power if tuned for. I have no idea how much pressure a usual fwd facing mopar scoop will generate at more moderate (140 mph) speeds, I intend to data log the pressure at the rear of the scoop next season and also reference the fuel pressure regulator to the same. Pretty sure something is happening as we do tend to drop around .4 AFR at the stripe, the caveat is I don't have enough data to prove if this attributable to the scoop or not. My
[Re: Neil]
#3179293
09/29/23 02:01 PM
09/29/23 02:01 PM
Tig
A shed in England
This is true, I had an unsealed glass hood with a small, 3" high six pack scoop. I only had 4 pins on it (2 front, 2 rear) and it used to lift in the middle at speed. I don't know if this was the scoop or just normal airflow through the front that caused this
[Re: dvw]
#3179334
09/29/23 03:21 PM
09/29/23 03:21 PM
Tig
A shed in England
The hood I had at the time wasn't the best available, it was a MAS one (1990's). It was eventually much modified and thus became really heavy, ended up with 8 pins. We have a nice lightweight flat hood with a hole for the T/R now and a clear makralon scoop.
[Re: 540DUSTER]
#3179480
09/30/23 12:49 AM
09/30/23 12:49 AM
Posts: 8,043 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Big scoops act like a parachute at speed. If the engine cant use all that air, its trapped.
[Re: Thelma133]
#3179490
09/30/23 05:19 AM
09/30/23 05:19 AM
Tig
A shed in England
Good article “ON ALL cylinders ” about this very topic. According to the article, it’s a wash. the horsepower gain is equal to the loss, created by drag, of the scoop. Can you post up a link ? TIA. Edit: Found it https://www.onallcylinders.com/2015...he-science-behind-hoop-scoop-technology/
[Re: Neil]
#3179508
09/30/23 08:51 AM
09/30/23 08:51 AM
Posts: 2,059 MD
RTSE4ME
MD
One guy had a purple 70 Challenger and the front middle area of the hood would lift up a bunch. He really needed to block off the grill opening with some clear lexan like some do, or add another pin in the middle as it was flexing the hood way more than I would be comfortable with. My car did that at 1000ft , the middle area of the hood would lift up a bunch. The bracing separated from hood skin.
[Re: Tig]
#3179511
09/30/23 08:53 AM
09/30/23 08:53 AM
jcc
Bitopia
A worthy article to read. But one question the article does not address. It is of course well accepted it takes horsepower to push an air intake scoop along at speed. And the claim in the article is the horsepower gain from any ram effect at speed is offset by the aero drag of the scoop. This is of course on this point ignored the at any speed the benefits of effectively cold intake air gains observed. My point here, in reality the car itself is effectively "drafting" behind the scoop, and reducing therefore the cars drag contribution, and that benefit is not addressed directly in the article and makes me wonder if overall the drag vs ram effect is indeed really a "wash".
