ferrea 2.14 valves #3179263
09/29/23 12:15 PM
09/29/23 12:15 PM
saint paul mn.
johnzgarage Offline OP
saint paul mn.
Anyone know where i might find 3 intake valves ? ferrea f6217 intake valve. I found three bent valves that im trying to replace. Sounds like Ferrea is out of stock.
Re: ferrea 2.14 valves [Re: johnzgarage] #3179270
09/29/23 12:42 PM
09/29/23 12:42 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Probably worth checking with Dwayne Porter (fast68plymouth) since I know he sells Ferrea
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: ferrea 2.14 valves [Re: Brad_Haak] #3179345
09/29/23 03:50 PM
09/29/23 03:50 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nothing I have, but you might try:
http://dpwferreavalves.com/
Re: ferrea 2.14 valves [Re: fast68plymouth] #3179359
09/29/23 04:32 PM
09/29/23 04:32 PM
saint paul mn.
saint paul mn.
Wow , I found 3 new valves , thanks for the help.
Re: ferrea 2.14 valves [Re: johnzgarage] #3180922
10/04/23 12:22 PM
10/04/23 12:22 PM
moparx Offline
moparx  Offline
happy to hear of a good outcome with help from our members. up
beer
