desperate to find these clips.
#317906
05/14/09 12:14 PM
05/14/09 12:14 PM
Posts: 4,233 petaluma,ca. u.s.a.
west
petaluma,ca. u.s.a.
these are the clips that hold the stainless trim on top of the door up against the glass on a 72 scamp. The clips have some kind of material in it to keep the water out.the newer ones(pictured on right) are from r/t specialties and don't have it nor do they fit properly.they are a slightly different shape. anyone know where to get these like the ones on the left? I have also tried mr. g's and can't find them.
Re: desperate to find these clips.
[Re: HEMICUDA]
#317910
05/14/09 02:28 PM
05/14/09 02:28 PM
Posts: 21,546 N.E. OHIO, USA
A12
N.E. OHIO, USA
I need some too. They are the same as for the belt line moldings on my 69 Cuda. The stuff inside them disintegrates pretty easily when you remove the clips plus I am missing some.
You mean these?
Michael, they look correct and yeah they are specific to that "belt line trim" application. In 2005 R/T Specialties pointed out the differences on that particular clip from others. I had to find used clips at swap meets that were left on that trim to finish my belt line trim. They are angled and the part that slides into the trim is an odd size and shape . Michael do you have those clips new
Thanks,
Mike
[Re: west]
#317913
05/14/09 06:05 PM
05/14/09 06:05 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
that looks a little different. what is it from?
After looking at the pictures closer, your original clip looks wider than the one I posted. My clip is from the 70-71 Cuda SS tail trim, it was originally used on the bottom leg of the end "C" pieces.
What is the over all width of the original and any other dimension you can get? I'm at home now and don't have access to the clip, I can check the difference in the morning.
