Re: New 727 transmission pan.
[Re: tboomer]
#3179047
09/28/23 05:56 PM
09/28/23 05:56 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
I kinda like the factory oem replacements. I have used them in the past. With or without drain lug.
https://www.ebay.com/itm/195888853794?epid=1340553650&hash=item2d9be2b322:g:g60AAOSwS1Nktsm1&amdata=enc%3AAQAIAAAAwBlB8OFAbo%2FypRyOJBmrZRY0ntz6BI47wcT6HkDAws%2Fbxuj1Ax0N3Wbs6R8hQDFOj0JIVxbu6jqx%2B%2FwY9XzA7urRmyExYxHxFqDhpDr%2B16V9apgsAvypAJ09hn7P5FSHvmu6fpAdqhknoa0yDnDdygbawW%2Bjb9sieJ%2F4xEZlcPd4lHHP1xSQ49xoOcn0RI4YNmcLNRkBKISgJuVW5YSFfZStMuhJY6xsiUnS5Fybb9ccfo2pozqvGpGE%2Be3XO1oDsw%3D%3D%7Ctkp%3ABk9SR9q979vbYg
https://www.ebay.com/itm/324604326460?hash=item4b93ecf23c:g:0RoAAMXQWzNSdszd&amdata=enc%3AAQAIAAAA4IlZO6jHfUN9lCqarzUHOq6l3qP%2BhVBel4pTPar%2BtXx6WddHoFRY4QguE7DdpWZksKTVu4d8eGZMqynKk2vYobon7Cclgf2m1GeZk%2B9qhsuTI2CS7fKgoi%2BjBf5%2F22XmIw%2Fd3Tf9AFtXVs5UX9rQvw1K4gL0iSIu8a2Rk2GlB03CJ4DsbXqddr0Cn%2BEhIYyfXtXXttZl58eS8dQIo7MrMh2zDlsqKIyI2ELhVp7OXHQFOoysFcML9q99ny1mohAWneM1nehlqpTsn0npZEh7l3ThQOe%2BFl6a6IgOdcTpE%2BqJ%7Ctkp%3ABFBM1L3v29ti
[Re: markz528]
#3179070
09/28/23 06:39 PM
09/28/23 06:39 PM
Posts: 20,668 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
From above https://www.ebay.com/itm/195888853794https://www.ebay.com/itm/324604326460Edit: Stumpy beat me to it. The factory plastic type gasket that goes with those OEM pans is great and works with any pan, but the dealers want a lot of money for them. They are reusable so the pain is a one time event. Also make sure if you get a thicker setup than stock that the bolts are long enough.
[Re: IMGTX]
#3179128
09/28/23 09:26 PM
09/28/23 09:26 PM
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Years ago I looked all over for a stock oem height raw steel pan and all I could find was deeper ones or chromed plated steel ones. If someone makes a stock replacement that would be cool, but I'm unsure if such a thing exists???
[Re: TJP]
#3179179
09/29/23 12:50 AM
09/29/23 12:50 AM
Posts: 20,189 Park Forest, IL
slantzilla
Park Forest, IL
We ran the deep A-500/R4X pan on my Valiant for 3 years when I was spraying it with no filter spacer. It didn't hurt anything. It was running low 12s then.
[Re: tboomer]
#3179729
09/30/23 10:44 PM
09/30/23 10:44 PM
slantzilla
Park Forest, IL
Ted, be aware that the thicker gasket needs longer bolts in some locations.
[Re: autoxcuda]
#3179765
10/01/23 12:54 AM
10/01/23 12:54 AM
Posts: 28,600 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I prefer the aluminum pans as they are less prone to distorting. I would too, but all cast aluminum pans are deeper than stock that I’ve found. The Summit Racing pan is priced well, made well and would dissipate heat as well. It is not super deep and would work on a street car.
