Page 2 of 15 1 2 3 4 14 15
Re: Slow progress [Re: HardcoreB] #3025234
03/18/22 06:23 PM
03/18/22 06:23 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
At first the new K frame would bolt up . Only three bolts went in . Pulled the rails in about 3/16 pretty much where the motor plate was . I guess a two piece motor plate is not as strong as a one Piece and will allow that to happen . After that the K bolted right up up
....BAD A$$ STREET CAR.....
Re: Slow progress [Re: n20mstr] #3025367
03/19/22 09:46 AM
03/19/22 09:46 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Man....this picture posting thing is not working for you is it?.......It's looking good tho up Good luck with it.
Re: Slow progress [Re: racerx] #3025442
03/19/22 01:29 PM
03/19/22 01:29 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
I'll see if I can rotate those for you:
Re: Slow progress [Re: mopowers] #3028245
03/28/22 07:43 AM
03/28/22 07:43 AM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Getting there
Re: Slow progress [Re: n20mstr] #3028263
03/28/22 09:03 AM
03/28/22 09:03 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Who's k frame
Re: Slow progress [Re: FastmOp] #3028306
03/28/22 11:10 AM
03/28/22 11:10 AM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Originally Posted by FastmOp
Who's k frame
Tory Shellehamer and Hotchkiss upper arms. Im making my own shock mount
Re: Slow progress [Re: FastmOp] #3028471
03/28/22 08:08 PM
03/28/22 08:08 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Who's k frame
Looks like one of Tory Shellhammer's K Frame. I saw one of Josh King's Dart as well
Alan Jones
Re: Slow progress [Re: LA360] #3031296
04/06/22 03:31 PM
04/06/22 03:31 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
I don’t know why these pics are flipped but …..it’s rolling again !
Re: Slow progress [Re: LA360] #3031298
04/06/22 03:41 PM
04/06/22 03:41 PM
NC
440Jim Offline
440Jim  Offline
NC
Good progress when it is a rolling chassis again. up up
Re: Slow progress [Re: n20mstr] #3031300
04/06/22 03:48 PM
04/06/22 03:48 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
boogie punkrocka
Drop me a PM when you see yourself coming down to Cecil County. Since I'm actually starting to get to the track on occasion, I'd like to see your ride run again in its new config.
There's possibility my old car may be capable of being rolled by Sunday evening, too. It'll still look like a junkyard refugee, but it would be a step in the right direction. Slow progress, indeed...
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Slow progress [Re: Brad_Haak] #3031343
04/06/22 05:59 PM
04/06/22 05:59 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Are you going to tie the motor plate into the snout bars? Though mine seems to be plenty sturdy I always wish I had, just to lazy.
Doug
Re: Slow progress [Re: Brad_Haak] #3031430
04/06/22 11:01 PM
04/06/22 11:01 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Originally Posted by Brad_Haak
boogie punkrocka
Will do !
Re: Slow progress [Re: dvw] #3031432
04/06/22 11:02 PM
04/06/22 11:02 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Doug
Yes running a 1.250 bar down to the frame behind the motor plate
Re: Slow progress [Re: n20mstr] #3031435
04/06/22 11:08 PM
04/06/22 11:08 PM
Rogue River, OR
Jeremiah Online work
Jeremiah  Online Work
Rogue River, OR
Looks great. Thanks for the update!
Re: Slow progress [Re: Jeremiah] #3032197
04/09/22 07:55 PM
04/09/22 07:55 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Lowered the back so I can check the trans/pinion angles while mounting the engine /Midplate
Re: Slow progress [Re: n20mstr] #3032203
04/09/22 08:33 PM
04/09/22 08:33 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Here. Thats hard on the roof, lol.
Re: Slow progress [Re: A990] #3032500
04/10/22 11:29 PM
04/10/22 11:29 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Looking great, Tony! It’s gonna run real good man!
"Any fool can know. The point is to understand"
- A. Einstein
Re: Slow progress [Re: EvilB1Dart] #3032597
04/11/22 01:00 PM
04/11/22 01:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Progress looks great. Love the ride height out back.
Re: Slow progress [Re: Al_Alguire] #3032612
04/11/22 01:37 PM
04/11/22 01:37 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
It can go lower, but right now the trans pan is 2.5" off the ground. Im in the process of removing the stock torsion bar crossmemeber. Then ill see how high i can get the trans into the stock tunnel. My cage is based on a "stock floorpan and firewall" so i cant cut out too much because im not adding a bunch of floor bars right now. I have the crank CL at 13.5 and thats with a 26" front tire. Again i can go lower but first im going to see what the trans pan ends up at....Right now its got a 3.5" pan on it, im thinking 2.25" pan. As far as engine oil pan....its going to be 5.5" deep.
Its getting there. Im getting the motorplate and midplate done, then im going to try and tackle these headers, not looking to cut up the firewall but.....its in the ay so..CHOP CHOP sawzall
Re: Slow progress [Re: n20mstr] #3042795
05/16/22 01:06 PM
05/16/22 01:06 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
CUt all the mild steel bars in the trunk area out, re mounting the shock crossmember into the trunk area, weight loss so far:
Trunk area 40lbs
Front suspension 65lbs
Steering column 20lbs
T bar crossmember 8lbs
Im going to weight the chromoly as it gets added back in the trunk, but the stock spare tire well (12lbs on its own) is not going back in
