Page 3 of 3 1 2 3
Re: OPENING IN BACK OF HOOD SCOOP? [Re: jcc] #3179516
09/30/23 08:25 AM
09/30/23 08:25 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
The last line says "It can improve the performance" I'm guessing the design has a lot to do with it, if this is the case. I'll be logging scoop pressure next season, interested to know if it works.
Re: OPENING IN BACK OF HOOD SCOOP? [Re: Pacnorthcuda] #3179530
09/30/23 08:57 AM
09/30/23 08:57 AM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
Originally Posted by Pacnorthcuda
ET is the definitive proof of concept.
We disagree, with maybe millions of variables, it may be the final goal, but not definitive proof.
I forbid my content here from being learned and used by artificial intelligence systems.
Re: OPENING IN BACK OF HOOD SCOOP? [Re: jcc] #3179533
09/30/23 09:05 AM
09/30/23 09:05 AM
Kirkland, Washington
Pacnorthcuda Offline
Sure it is, just gotta hold the other variables constant, which is commonly done in drag racing.
Re: OPENING IN BACK OF HOOD SCOOP? [Re: Pacnorthcuda] #3179536
09/30/23 09:42 AM
09/30/23 09:42 AM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
Good luck with that thought.
Even in a highly "controlled" wind tunnel, they run multiple runs to find an average and account for the variables unknown or what that they can't control.
Re: OPENING IN BACK OF HOOD SCOOP? [Re: jcc] #3179645
09/30/23 04:26 PM
09/30/23 04:26 PM
There is no way I would cut holes the backside of any hood scoop to lower the pressure around the carb tsk
I do run air cleaners now on all of my race motors with and without a scoop up That helps prevent the air flowing across the top of the carb with no air cleaner on from sucking fuel out of the top of the carb. up scope twocents
Re: OPENING IN BACK OF HOOD SCOOP? [Re: Cab_Burge] #3179748
09/30/23 10:53 PM
09/30/23 10:53 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
In another tjought ,
It seems some use filters some dont , i use a screen . Would a deflecter across / in front of carb intake help , stop air straight over carb ? Or could it introduce further turbulence ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.94
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: OPENING IN BACK OF HOOD SCOOP? [Re: tex013] #3179834
10/01/23 09:58 AM
10/01/23 09:58 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Only testing will tell.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: OPENING IN BACK OF HOOD SCOOP? [Re: tex013] #3179861
10/01/23 11:36 AM
10/01/23 11:36 AM
Here
jcc Offline
No soup for you!!!
jcc  Offline
No soup for you!!!
Here
Tex
Testing likely will show what the result might be, but it will NOT tell you why something is causing the result, so many just seem to pick one and go from there.
Re: OPENING IN BACK OF HOOD SCOOP? [Re: jcc] #3180497
10/03/23 07:56 AM
10/03/23 07:56 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
For the most part, I'm with "JCC" and his inputs here. Especially when it comes to 'why' a configuration 'works'. Some of us have dumb-luck when it comes down to what 'works'. There's a decent amount of 'engineering' that goes into any scoop that functions to it's capacity. As much as this subject seems to be beating a dead-horse I'm glad to see some evolution in thinking is happening.
Re: OPENING IN BACK OF HOOD SCOOP? [Re: HardcoreB] #3180788
10/03/23 09:50 PM
10/03/23 09:50 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I opened up the back of the scoop at the hood is really lifting and crushed the hood pin bracket and have bent the hood pins
I was amazing how high the hood bowed at the end of the quarter. About 141-142 mph
It is not enough to help the situation and I will need to do a different hood with a different scoop as the holes only partially helped
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Page 3 of 3 1 2 3
