Re: Lets see your G3 Street Strip combos and ET
[Re: Dragula]
#3174776
09/12/23 06:49 PM
09/12/23 06:49 PM
Posts: 2,892 Pattison Texas
CSK
Pattison Texas
Wow....You guys are a plethora of knowledge. Either that, or you have other hobbies. All I have is my bone stock 2020 T/A 392 11.79 @ 114.5 13mph head wind 4445 lbs race weight , Wallace says about 538FW hp, wish I had more for ya
[Re: w2stroker]
#3175495
09/15/23 09:50 PM
09/15/23 09:50 PM
Posts: 8,046 Tulsa OK
Bad340fish
Tulsa OK
Ray Meyer's combo that ran 9.70s back in 2016 is one I would like to duplicate if I built an NA Hemi. 9.70s on pump gas at 3200ish lbs is pretty awesome in my book.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3175556
09/16/23 09:03 AM
09/16/23 09:03 AM
Posts: 20,222 PA.
pittsburghracer
"Little"John
"Little"John
PA.
One on forabodiesonly just went 6.30 at 2900 pounds NA. Races weekly.
[Re: pittsburghracer]
#3176566
09/20/23 07:11 AM
09/20/23 07:11 AM
Posts: 3,882 Smyrna, South Carolina
STEFF
Mine and my Son's Street/Strip cars. My Road Runner, 3150 lbs, 425" Gen 3 Hemi, 12:1 compression, Thitek Heads, NA, Full Interior, drive it around on weekends and to work once a week, usually, pump gas on the street, MS109 at the track, best so far 9.04 @ 147, 5.73 @ 119, 1.27 60ft. My Son's Duster, 3020 lbs, 428" Gen 3 Hemi, BGE Heads, Fogger, 12.5:1 compression, Caltracs/Sliders on rear, 26 x 8.5 Tire, Totally stock front suspension, Full Interior, drive it around on weekends and to work occasionally, pump gas on street, C23 at the track, Runs RTRA Limited Street 235 Class, best so far 5.15 @ 132, 1.15 60ft, on an .036 jet. Had an engine mishap in February at Lights Out, just got motor back together. Goal is high 4.90's. We're about 70lbs heavy for the class as well. Only need to weigh 2950. That will be rectified this off season. 2023-09-20_06-53-24 by Stephen Rimay 20210531_160429 by Stephen Rimay 2023-09-20_07-16-46 by Stephen Rimay 20221028_103913 by Stephen Rimay 2023-09-20_07-13-49 by Stephen Rimay
[Re: STEFF]
#3176593
09/20/23 09:49 AM
09/20/23 09:49 AM
Posts: 20,222 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A couple of nice running cars right there.
[Re: STEFF]
#3176594
09/20/23 09:52 AM
09/20/23 09:52 AM
CSK
Pattison Texas
pure AWESOMENESS !!!!!!!!!
[Re: CSK]
#3176981
09/21/23 04:50 PM
09/21/23 04:50 PM
Posts: 1,246 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Yeah, those are some pretty stout G3 combinations ![drool drool](/ubbthreads/images/graemlins/custom/drool.gif)
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Dragula]
#3177342
09/23/23 12:22 AM
09/23/23 12:22 AM
Posts: 80 Australia
aus370
Australia
it's expensive in Australia, So its a budget engine. 77 Valiant , 6.4 with drop in pistons & rods, home ported heads , stock valves , ported 6.1 intake 95 mm TB , HC injectors, 239/251 .605 Johnson short travels . Pump fuel, 904 TF, 5000+ converter, 3.89 gears , around 3500lb race weight. Best 1/4 10.49 @ 126.7 best 1/8 6.61 @ 102.7 . [i][/i]
2023
[Re: w2stroker]
#3177501
09/23/23 02:52 PM
09/23/23 02:52 PM
Posts: 12,442 Taxes & Virus's R-US, NY
Dragula
10.19 @ 132 on pump gas. 6.4 block. 11 to 1 compression, thitek heads. comp cam 256/266 @ .050 .613 lift, ritter intake with 1050. That is a sexy car...
[Re: aus370]
#3178078
09/25/23 01:15 PM
09/25/23 01:15 PM
Bad340fish
Tulsa OK
it's expensive in Australia, So its a budget engine. 77 Valiant , 6.4 with drop in pistons & rods, home ported heads , stock valves , ported 6.1 intake 95 mm TB , HC injectors, 239/251 .605 Johnson short travels . Pump fuel, 904 TF, 5000+ converter, 3.89 gears , around 3500lb race weight. Best 1/4 10.49 @ 126.7 best 1/8 6.61 @ 102.7 . [i][/i] That is impressive, what is the density altitude like when you run those ETs?
[Re: cudadoug]
#3178297
09/26/23 10:45 AM
09/26/23 10:45 AM
STEFF
I'm digging that old school snorkel scoop on the small tire Duster!
Steff, can you share what the Roadrunner weighs? 3150
[Re: STEFF]
#3178326
09/26/23 11:53 AM
09/26/23 11:53 AM
Posts: 1,567 Michigan
Kiddart
If all goes well i should have numbers from my build this weekend
Thank you Kiddart
[Re: Bad340fish]
#3178416
09/26/23 03:42 PM
09/26/23 03:42 PM
Posts: 80 Australia
aus370
Australia
it's expensive in Australia, So its a budget engine. 77 Valiant , 6.4 with drop in pistons & rods, home ported heads , stock valves , ported 6.1 intake 95 mm TB , HC injectors, 239/251 .605 Johnson short travels . Pump fuel, 904 TF, 5000+ converter, 3.89 gears , around 3500lb race weight. Best 1/4 10.49 @ 126.7 best 1/8 6.61 @ 102.7 . [i][/i] That is impressive, what is the density altitude like when you run those ETs? Pretty good, the DA on !/4 mile was 11ft , the 1/8 was 284 ft .
