Re: My Luck is not Improving
[Re: Dragula]
#3177511
09/23/23 03:27 PM
09/23/23 03:27 PM
Posts: 10,018 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Went to TNT and this happened on the first pass.... Hard to tell, backfire and fire? Any serious damage beyond what can be seen?
[Re: Dragula]
#3177530
09/23/23 05:15 PM
09/23/23 05:15 PM
Posts: 1,559 Michigan
Kiddart
Maybe a bigger hole in the hood. if you are really hauling the mail the air has nowhere to go so something has to give
Thank you Kiddart
[Re: Kiddart]
#3177535
09/23/23 05:29 PM
09/23/23 05:29 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
Well, on the bright side, if you got crossed up enough on the big end, it would still be effective. ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif)
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: quickd100]
#3177557
09/23/23 07:29 PM
09/23/23 07:29 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
When you race stuff happens. That’s minor and not worth a second thought.
[Re: Moparrob68]
#3177912
09/24/23 09:08 PM
09/24/23 09:08 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
Well you should have expected that after it was 1/4 of the way off after your pass last week. Did you run out of Gorilla glue? Apparently the Gorilla Glue is not strong enough....
[Re: Dragula]
#3178164
09/25/23 05:56 PM
09/25/23 05:56 PM
Posts: 1,115 Usa
A39Coronet
Usa
Probably a good indication that if you ran the formula for hood scoop size vs engine demand you'd find the scoop is too big and creating excessive drag. Thankfully it didn't damage the windshield tho.
[Re: A39Coronet]
#3178273
09/26/23 09:04 AM
09/26/23 09:04 AM
Posts: 2,527 PA
moparacer
PA
Scoops can catch a ton of air. Years ago when I put a 440 6 pack hood on my old Duster the first pass I noticed it was bowing up in the middle bad. This was only running mid 11s. It broke the middle support. I figured it was cracked or something so the next week fixed and supported it and it broke it again.... ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) It was a hinge latch setup and the scoop caught so much air it pulled the latch setup out of the hood eventually. Had to pin it down.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Dragula]
#3178284
09/26/23 09:36 AM
09/26/23 09:36 AM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
Don't you have a cowl hood for that car? It's probably faster. ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif)
[Re: Dragula]
#3178294
09/26/23 10:27 AM
09/26/23 10:27 AM
Posts: 17,912 S.E. Michigan
ZIPPY
S.E. Michigan
A minor Oopsie.
A mere flesh wound.
Rich H.
Esse Quam Videri
