8 speed auto install #3177226
09/22/23 03:15 PM
09/22/23 03:15 PM
houston texas
gremlinsteve Offline OP
houston texas
Has anyone installed one of the new 8 speeds into a d series truck yet
Pic for attention
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: 8 speed auto install [Re: gremlinsteve] #3177310
09/22/23 08:23 PM
09/22/23 08:23 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Are you on Facebook? There is a group on there that all the group is about is installing the 8 speed into mopar cars and magnum engines
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 8 speed auto install [Re: mopar65] #3177327
09/22/23 10:54 PM
09/22/23 10:54 PM
houston texas
houston texas
Yes
I just found a couple of swap groups
Re: 8 speed auto install [Re: gremlinsteve] #3177592
09/23/23 08:58 PM
09/23/23 08:58 PM
Green Bay
Andyvh1959 Offline
Andyvh1959  Offline
Green Bay
There is a guy on the Facebook group for the 8HP trans, he installed the 8-spd trans behind the 318 in his 88 D150. The 8HP bolts right up to the Hemi/318/5.2/340/360/5.9 block. He used a flex plate from a GM 4L60, and drilled it to match the 8HP torque converter. Then he bought a custom harness from Sound German Automotive, he said it was a plug and play setup. The 8HP needs a signal from the TPS, tach signal for rpm, and a connection to the reverse switch. He said after some test driving the TCM learns the setup and everything worked great. He even said his D150 now gets 22mpg on the highway.
My 56 C3-B8 Dakota build
Re: 8 speed auto install [Re: Andyvh1959] #3177625
09/23/23 11:07 PM
09/23/23 11:07 PM
houston texas
houston texas
Awesome information
I joined a Facebook group and I’ll search him out
I’m running a low deck big block so I’m going to have to purchase the jvx adapter setup
But I’m highly motivated in this
Re: 8 speed auto install [Re: Andyvh1959] #3177665
09/24/23 07:33 AM
09/24/23 07:33 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
That is very interesting.
https://en.wikipedia.org/wiki/ZF_8HP_transmission
With “potential” 3.7 first gear and 0.64 overdrive maybe even 2.76 diff ratio could be used up to 1% grade hills on Interstate cruising.
Gotta take it on faith that
“ One of its main aims is to improve vehicle fuel economy, and it can achieve 12% saving compared to the ZF 6HP transmission and 14% versus modern 5-speed transmissions.”
as those internal trans gear friction reductions “boogle my brain”.
I suspect they are “wrapping in” fuel economy improvement due to lower engine rpm and wider throttle opening
Re: 8 speed auto install [Re: 360view] #3178048
09/25/23 12:32 PM
09/25/23 12:32 PM
Green Bay
Andyvh1959 Offline
Andyvh1959  Offline
Green Bay
With some diligent and patient FBM shopping, deals can be found to buy a used 8HP-70. I found one in Chicago for $700, but the seller never replied to me after I sent him an offer he accepted, so he lost out. Then two days later I was in central Indiana for work and searched FBM in my hotel room. Found a 8HP-70 complete with the torque converter, cooler hoses/tubes and complete driveshaft, came out of a 2016 Challenger with 50,000 miles on it, bought it for $400. Seller wasn't aware the 8HP would mount to any engine with the same bellhousing bolt pattern as a 6.7 Hemi. After I gave him the $400 I said I've heard of guys mounting the 8HP behind 318, 5.2, 360, 5.9, 340 engines. Then he said he should have hung onto the trans, heh, heh.
