Re: rare bracket behind steering gear box on 89 Ram
[Re: 1moparman]
#31767
10/26/06 12:41 PM
10/26/06 12:41 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
What did these come out on? Does my 86 have one?
Lee
Moparlee
[Re: scratchnfotraction]
#31768
10/26/06 12:48 PM
10/26/06 12:48 PM
Posts: 1,449 Orange Park FL.
LilRed7879
Orange Park FL.
I could/would use one when you do repop them.
10-4 I will keep a list - and will of course be posting here also.
Thank you MOPARTS - for helping everyone share info!!
[Re: Robbins]
#31770
10/26/06 04:37 PM
10/26/06 04:37 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
Lee
My old '86 didn't have one, I didn't know they existed 'til I was poking around the '88 I just picked up.
[Re: oleman]
#31775
10/27/06 05:03 PM
10/27/06 05:03 PM
MoparJoe
super gas
super gas
Tampa , Fl
My 85 ramcharger 2wd does not have one. After 21 years the frame still looks good. Down here in rust-free Dallas. Could be it was for 4wd.
No rust on mine either but when you turn the wheel you can see the frame flexing.
[Re: Dallasdan]
#31777
10/27/06 09:32 PM
10/27/06 09:32 PM
Posts: 1,011 Sunnyvale, CA.
3XCHARM
Sunnyvale, CA.
Welding might help your situation, but most of the Dodge frames flex in this area. I just had to repair my 2wd frame behind the steering box. The bracket would be easy to make, or for the ultimate try boxing the frame. http://rockcharger.com/rcs/rockcharger/crossover2.htmlThis isnt my info, it is some that was found on the web.
1975 Ramcharger 6" lift 35" Mud Terrains 8 lug 44 front, 60 rear. (R.I.P.) 1976 D100 lowered 3" & 5" Now with a 440!!! (sold) On the hunt for another beauty to build.
[Re: 4dr4x4]
#31779
10/28/06 09:36 AM
10/28/06 09:36 AM
Posts: 2,597 A Happy Place, A Happy Place, ...
57Plymouth
I don't have the bracket, but I wish I did. I had a badly cracked frame on my 2wd when I rebuilt it, and the strut rod pockets had broken free of the front crossmember. I spent a lot of time drilling and grinding cracks and welding it all up. I also put a plate over both sides of the frame(clearanced for the steering box) and welded all of the crossmembers solid to the side rails. I also gusseted the front crossmember to the side rails and boxed in the side rails. Mine is stiff (VERY stiff) but I still want that little brace.
Virtus Junxit Mors Non Separabit
