Page 1 of 3 1 2 3
rare bracket behind steering gear box on 89 Ram #31763
10/26/06 09:54 AM
10/26/06 09:54 AM
Crockett ,TX
9
98RAM1500 Offline OP
Crockett ,TX
heres a pick of this bracket that i was told helps old the gear box to the frame
Re: rare bracket behind steering gear box on 89 Ram [Re: 98RAM1500] #31764
10/26/06 10:01 AM
10/26/06 10:01 AM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
Yes this bracket is considered a must have on most later 70's to 80's dodge trucks - we are in the process of getting someone to reproduce it since chrysler saw fit to quit making it about 10 years ago.
David S.
Re: rare bracket behind steering gear box on 89 Ram [Re: LilRed7879] #31765
10/26/06 10:19 AM
10/26/06 10:19 AM
scratchnfotraction Offline
I could/would use one when you do repop them.
Re: rare bracket behind steering gear box on 89 Ram [Re: scratchnfotraction] #31766
10/26/06 12:15 PM
10/26/06 12:15 PM
lakeside ca
1moparman Offline
1moparman  Offline
lakeside ca
ditto
Get Real Get Mopar
Re: rare bracket behind steering gear box on 89 Ram [Re: 1moparman] #31767
10/26/06 12:41 PM
10/26/06 12:41 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
What did these come out on? Does my 86 have one?
Lee
Moparlee
Re: rare bracket behind steering gear box on 89 Ram [Re: scratchnfotraction] #31768
10/26/06 12:48 PM
10/26/06 12:48 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
10-4 I will keep a list - and will of course be posting here also.
Thank you MOPARTS - for helping everyone share info!!
Re: rare bracket behind steering gear box on 89 Ram [Re: LilRed7879] #31769
10/26/06 01:09 PM
10/26/06 01:09 PM
Crockett ,TX
9
Crockett ,TX
well my 81 ram doesn't have one and a 79 warlock i had didn't had one either
Re: rare bracket behind steering gear box on 89 Ram [Re: Robbins] #31770
10/26/06 04:37 PM
10/26/06 04:37 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Lee
My old '86 didn't have one, I didn't know they existed 'til I was poking around the '88 I just picked up.
Re: rare bracket behind steering gear box on 89 Ram [Re: MoparJoe] #31771
10/26/06 07:16 PM
10/26/06 07:16 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
the brackets didnt come out on anything from the factory assy line. they were a factory fixit for weak frames in the steering box area..
I am truckless..
Re: rare bracket behind steering gear box on 89 Ram [Re: 340SHORTY] #31772
10/26/06 11:39 PM
10/26/06 11:39 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Good to know - I had to repair my '86 for that reason- the frame broke in front of the box, the '88 is solid in that area so I guess the bracket works.
Re: rare bracket behind steering gear box on 89 Ram [Re: MoparJoe] #31773
10/27/06 11:40 AM
10/27/06 11:40 AM
Crockett ,TX
9
Crockett ,TX
I will probably sell this one I have, I will clean it up and shoot some primer on it to help keep it from rusting or some black engine enamel
Re: rare bracket behind steering gear box on 89 Ram [Re: 98RAM1500] #31774
10/27/06 11:44 AM
10/27/06 11:44 AM
North Texas
O
oleman Offline
oleman  Offline
O
North Texas
My 85 ramcharger 2wd does not have one. After 21 years the frame still looks good. Down here in rust-free Dallas. Could be it was for 4wd.
Re: rare bracket behind steering gear box on 89 Ram [Re: oleman] #31775
10/27/06 05:03 PM
10/27/06 05:03 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
No rust on mine either but when you turn the wheel you can see the frame flexing.
Re: rare bracket behind steering gear box on 89 Ram [Re: MoparJoe] #31776
10/27/06 08:10 PM
10/27/06 08:10 PM
Midlothian TX USA
Dallasdan Offline
Dallasdan  Offline
Midlothian TX USA
Mine flexes too. I was just gonna weld the driver side area - I think the rivets are loosening. Not trying to hijack here - has anyone had to use this bracket after simply welding? Just curious if I should start watching for the sale of this bracket?
Re: rare bracket behind steering gear box on 89 Ram [Re: Dallasdan] #31777
10/27/06 09:32 PM
10/27/06 09:32 PM
Sunnyvale, CA.
3XCHARM Offline
3XCHARM  Offline
Sunnyvale, CA.
Welding might help your situation, but most of the Dodge frames flex in this area. I just had to repair my 2wd frame behind the steering box. The bracket would be easy to make, or for the ultimate try boxing the frame.
http://rockcharger.com/rcs/rockcharger/crossover2.html
This isnt my info, it is some that was found on the web.
1975 Ramcharger 6" lift 35" Mud Terrains 8 lug 44 front, 60 rear. (R.I.P.)
1976 D100 lowered 3" & 5" Now with a 440!!! (sold)
On the hunt for another beauty to build.
Re: rare bracket behind steering gear box on 89 Ram [Re: 98RAM1500] #31778
10/28/06 12:48 AM
10/28/06 12:48 AM
Winnipeg, Manitoba, Canada
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
So far I have seen two different brackets. Check out the picture, the one looks much stronger than the other. I have seen a few of the flat style brackets that were cracked where they bolt to the cross member.
Re: rare bracket behind steering gear box on 89 Ram [Re: 4dr4x4] #31779
10/28/06 09:36 AM
10/28/06 09:36 AM
A Happy Place, A Happy Place, ...
57Plymouth Offline
57Plymouth  Offline
I don't have the bracket, but I wish I did. I had a badly cracked frame on my 2wd when I rebuilt it, and the strut rod pockets had broken free of the front crossmember. I spent a lot of time drilling and grinding cracks and welding it all up. I also put a plate over both sides of the frame(clearanced for the steering box) and welded all of the crossmembers solid to the side rails. I also gusseted the front crossmember to the side rails and boxed in the side rails. Mine is stiff (VERY stiff) but I still want that little brace.
Virtus Junxit Mors Non Separabit
Re: rare bracket behind steering gear box on 89 Ram [Re: 57Plymouth] #31780
10/28/06 01:22 PM
10/28/06 01:22 PM
Crockett ,TX
9
Crockett ,TX
heres another pic of it off the truck and primered
Re: rare bracket behind steering gear box on 89 Ram [Re: 98RAM1500] #31781
10/28/06 07:15 PM
10/28/06 07:15 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Kind of related, but there was/is a factory recall on Dodge vans of the '74-'77 era because of the same problem- a crack develops in the frame rail near the steering gear box. Very common, unfortunately.
Re: rare bracket behind steering gear box on 89 Ram [Re: 57Plymouth] #31782
10/28/06 10:28 PM
10/28/06 10:28 PM
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
When I had the safty check done on my truck they told me the frame was moving when you turn the wheels. They wanted me to remove the rivits and bolt the front cross member on. I told them about the bracket and they said I could go with that. I made the bracket on my truck even stronger by adding more metel and welding up the seems. The truck handles realy good so I guess it works. I will try to get a picture of the one I installed on my truck. It would be very hard to bend or crack that one.
Page 1 of 3 1 2 3
