Options for rear 1/4 glass when removing vinyl top #3176051
09/18/23 01:47 PM
09/18/23 01:47 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
What are the options I have when removing a vinyl top from a car with the plastic filler panels to make the little opera windows? Car is a 1977 Gran Fury 2 door
I need to remove the top to save the roof, but don't have money to have the top replaced right now. I know there are full windows under the panels.
I am not opposed to running the exposed rear 1/4 glass, just not sure how to trim it out so it looks decent, and isn't just sitting there with a gaping void or something in the trim and fit.
I attached a couple pictures, one with one without the filler panel.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Options for rear 1/4 glass when removing vinyl top [Re: hp383] #3181325
10/05/23 12:22 PM
10/05/23 12:22 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
well poop
Re: Options for rear 1/4 glass when removing vinyl top [Re: hp383] #3181356
10/05/23 01:19 PM
10/05/23 01:19 PM
IMGTX Offline
IMGTX  Offline
On the cars I worked with there was a plastic plug covering the window installed with screws. That was all covered by the top.
Most of those cars had fixed windows so the weather stripping was sometimes different but would look normal enough.
I think you are just going to have to remove the top and the plug. Plug up the small screw holes and clean up the glue.
Re: Options for rear 1/4 glass when removing vinyl top [Re: hp383] #3181531
10/05/23 10:20 PM
10/05/23 10:20 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
They do still make the flexible plastic chrome wheel moldings I believe, Might be able to do something with those or paint the top a different color and trim it with the same , Just trying to think outside the box beer
