Lets see your G3 Street Strip combos and ET #3174409
09/11/23 01:19 PM
09/11/23 01:19 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Might be really looking at getting into a G3 and want to see what kind of builds you guys have done. I really like Ray's old Barracuda with a NA G3 which I think sports a tunnel ram now. But boosted builds welcome.
'70 Cuda,...605 Hemi Street Car (6.20 best pass, 1.33 60ft)
Re: Lets see your G3 Street Strip combos and ET [Re: Dragula] #3174617
09/12/23 11:27 AM
09/12/23 11:27 AM
Dragula Offline OP
Dragula  Offline OP
Wow....You guys are a plethora of knowledge. Either that, or you have other hobbies.
Re: Lets see your G3 Street Strip combos and ET [Re: Dragula] #3174776
09/12/23 06:49 PM
09/12/23 06:49 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
All I have is my bone stock 2020 T/A 392 11.79 @ 114.5 13mph head wind 4445 lbs race weight , Wallace says about 538FW hp, wish I had more for ya smile
Re: Lets see your G3 Street Strip combos and ET [Re: CSK] #3174874
09/13/23 08:40 AM
09/13/23 08:40 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Me too..All I have is my slow little bracket car. Not many drag week type cars running Gen III.
Other than Ray I know Dave Weber at MMX maybe a couple more.
If I wanted to build one it would be boosted with a Whipple 3.0.
Re: Lets see your G3 Street Strip combos and ET [Re: RTSE4ME] #3174910
09/13/23 12:05 PM
09/13/23 12:05 PM
Dragula Offline OP
Dragula  Offline OP
I think that new Whipple 3.0 is so ugly....
Re: Lets see your G3 Street Strip combos and ET [Re: Dragula] #3175191
09/14/23 03:41 PM
09/14/23 03:41 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
I have a 5.7 Hemi in a 73 Challenger. The engine has drop in pistons, TSP cam 226/235 .582/.582 114+3, Prefix single plane intake, MPI with Holley 1000 cfm throttle body and a Torqstorm supercharger. The car weighs about 3700 lbs with driver. Best ET 10.31 at 132.70 mph with a really lazy 1.5649 60’ time. The car has been 1.43 60’ time with a 430 LA SBM. The car should run high 9s with a transbrake and launching with boost.
Re: Lets see your G3 Street Strip combos and ET [Re: 416challenger] #3175305
09/15/23 08:29 AM
09/15/23 08:29 AM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
10.19 @ 132 on pump gas. 6.4 block. 11 to 1 compression, thitek heads. comp cam 256/266 @ .050 .613 lift, ritter intake with 1050.
Re: Lets see your G3 Street Strip combos and ET [Re: w2stroker] #3175495
09/15/23 09:50 PM
09/15/23 09:50 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Ray Meyer's combo that ran 9.70s back in 2016 is one I would like to duplicate if I built an NA Hemi. 9.70s on pump gas at 3200ish lbs is pretty awesome in my book.
68 Barracuda Formula S 340
87 "Chrysler" Conquest
Re: Lets see your G3 Street Strip combos and ET [Re: Bad340fish] #3175556
09/16/23 09:03 AM
09/16/23 09:03 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
One on forabodiesonly just went 6.30 at 2900 pounds NA. Races weekly.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Lets see your G3 Street Strip combos and ET [Re: pittsburghracer] #3176566
09/20/23 07:11 AM
09/20/23 07:11 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Mine and my Son's Street/Strip cars.
My Road Runner, 3150 lbs, 425" Gen 3 Hemi, 12:1 compression, Thitek Heads, NA, Full Interior, drive it around on weekends and to work once a week, usually, pump gas on the street, MS109 at the track, best so far 9.04 @ 147, 5.73 @ 119, 1.27 60ft.
My Son's Duster, 3020 lbs, 428" Gen 3 Hemi, BGE Heads, Fogger, 12.5:1 compression, Caltracs/Sliders on rear, 26 x 8.5 Tire, Totally stock front suspension, Full Interior, drive it around on weekends and to work occasionally, pump gas on street, C23 at the track, Runs RTRA Limited Street 235 Class, best so far 5.15 @ 132, 1.15 60ft, on an .036 jet. Had an engine mishap in February at Lights Out, just got motor back together. Goal is high 4.90's. We're about 70lbs heavy for the class as well. Only need to weigh 2950. That will be rectified this off season.
[Linked Image]2023-09-20_06-53-24 by Stephen Rimay
[Linked Image]20210531_160429 by Stephen Rimay
[Linked Image]2023-09-20_07-16-46 by Stephen Rimay
[Linked Image]20221028_103913 by Stephen Rimay
[Linked Image]2023-09-20_07-13-49 by Stephen Rimay
Re: Lets see your G3 Street Strip combos and ET [Re: STEFF] #3176593
09/20/23 09:49 AM
09/20/23 09:49 AM
PA.
"Little"John
"Little"John
PA.
A couple of nice running cars right there.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Lets see your G3 Street Strip combos and ET [Re: STEFF] #3176594
09/20/23 09:52 AM
09/20/23 09:52 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
pure AWESOMENESS !!!!!!!!!
Re: Lets see your G3 Street Strip combos and ET [Re: CSK] #3176981
09/21/23 04:50 PM
09/21/23 04:50 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Yeah, those are some pretty stout G3 combinations drool
2021 Challenger 6.4L Scat Pack 1320 (2022)
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
wheels, tires, air filter: 1.714, 11.833 at 115.80 (DA 310 ft)
1973 Challenger 452 ci street/strip (2008)
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Lets see your G3 Street Strip combos and ET [Re: Dragula] #3177342
09/23/23 12:22 AM
09/23/23 12:22 AM
Australia
aus370 Offline
aus370  Offline
Australia
it's expensive in Australia, So its a budget engine. 77 Valiant , 6.4 with drop in pistons & rods, home ported heads , stock valves , ported 6.1 intake 95 mm TB , HC injectors, 239/251 .605 Johnson short travels .
Pump fuel, 904 TF, 5000+ converter, 3.89 gears , around 3500lb race weight. Best 1/4 10.49 @ 126.7 best 1/8 6.61 @ 102.7 .
[i][/i]
2023
Re: Lets see your G3 Street Strip combos and ET [Re: w2stroker] #3177501
09/23/23 02:52 PM
09/23/23 02:52 PM
Dragula Offline OP
Dragula  Offline OP
That is a sexy car...
Re: Lets see your G3 Street Strip combos and ET [Re: STEFF] #3178034
09/25/23 11:51 AM
09/25/23 11:51 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I'm digging that old school snorkel scoop on the small tire Duster!
Steff, can you share what the Roadrunner weighs?
Re: Lets see your G3 Street Strip combos and ET [Re: aus370] #3178078
09/25/23 01:15 PM
09/25/23 01:15 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
[i][/i]
That is impressive, what is the density altitude like when you run those ETs?
Re: Lets see your G3 Street Strip combos and ET [Re: cudadoug] #3178297
09/26/23 10:45 AM
09/26/23 10:45 AM
STEFF Offline
STEFF  Offline
3150
Re: Lets see your G3 Street Strip combos and ET [Re: STEFF] #3178326
09/26/23 11:53 AM
09/26/23 11:53 AM
K
Kiddart Offline
Kiddart  Offline
K
If all goes well i should have numbers from my build this weekend
Thank you
Kiddart
Re: Lets see your G3 Street Strip combos and ET [Re: Bad340fish] #3178416
09/26/23 03:42 PM
09/26/23 03:42 PM
Australia
aus370 Offline
aus370  Offline
Australia
[i][/i]
Pretty good, the DA on !/4 mile was 11ft , the 1/8 was 284 ft .
