Fan / clutch Mounting Bolts #3175431
09/15/23 05:27 PM
09/15/23 05:27 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Just double checking , but were there any washers used on the bolts that attach fan clutch/fan onto water pump shaft ? I don't think so , please verify.
1970 DODGE challenger T/A 340 Thanks !!! Kevin
Re: Fan / clutch Mounting Bolts [Re: B5TA] #3175442
09/15/23 05:49 PM
09/15/23 05:49 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
I've never seen any on clutch setups. hth
Re: Fan / clutch Mounting Bolts [Re: B5TA] #3175479
09/15/23 07:57 PM
09/15/23 07:57 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Fan to clutch. Yes
Clutch to water pump. No
Re: Fan / clutch Mounting Bolts [Re: gtx6970] #3175492
09/15/23 09:41 PM
09/15/23 09:41 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
THANK yOU ! Kevin
Re: Fan / clutch Mounting Bolts [Re: gtx6970] #3175641
09/16/23 01:51 PM
09/16/23 01:51 PM
moparx Offline
moparx  Offline
Originally Posted by gtx6970
Fan to clutch. Yes
i believe this to be correct.
beer
Re: Fan / clutch Mounting Bolts [Re: A990] #3175664
09/16/23 02:54 PM
09/16/23 02:54 PM
iagree up
I do add them,(AN type flat washers) on all the motors I assemble with both clutches and fans with spacers up twocents
Re: Fan / clutch Mounting Bolts [Re: Cab_Burge] #3175783
09/17/23 09:57 AM
09/17/23 09:57 AM
VA
dragon slayer Offline
VA
The bolts to water pump for the fan clutch are "place" bolts and NO washers. They have a designed flat under head. Fan to clutch had studs and conical washer and nut.
