Re: Radiator leak
[Re: TJP]
#3172278
09/02/23 11:27 AM
09/02/23 11:27 AM
Posts: 15,938 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I'm getting ready to do a maintenance flush and refill.
I'm interested also; Green Prestone or is there something better in the old school stuff?
Facts are stubborn things.
Re: Radiator leak
[Re: topside]
#3172457
09/02/23 09:16 PM
09/02/23 09:16 PM
Posts: 21,545 N.E. OHIO, USA
A12
N.E. OHIO, USA
Water cools better than anti-freeze, so unless you need protection against freezing, 25-30% anti-freeze is fine. Did that on my Dually, along with a little lower temp thermostat, and brought coolant temp down a good 10 degrees. On the older stuff, the green anti-freeze is fine. You also need protection against RUST. Ask the boat owners about cast iron block and steel component coolant system rust. My original Sea Ray boat motor (5.0L) needed to be replaced and tried to get a local engine builder to try and save it which he said at the time he couldn't get to it for a many weeks. I said then I'll just find a remanufactured boat engine and that's when he warned me about boat motors don't use anti-freeze or coolant and there's no telling how thin a cast iron boat engine block might be on rebuilt/remanufactured boat engines. So off to Summit and bought a NEW 5.7L crate motor, changed the freeze plugs to brass, a new Melling cam that fit the boat motor rpm characteristics and a marine fuel pump. Picked up 65 hp and a brand new cast-iron block and cast-iron heads. Yes water cools better but it will also cause rust that could be an issue in the radiator, water pump, thermostat, etc., Just saying.
Re: Radiator leak
[Re: topside]
#3175054
09/13/23 09:53 PM
09/13/23 09:53 PM
Posts: 15,508 Omaha Ne
TJP
Omaha Ne
^^^ That, and "run" the heater to flush all that out as well. No better time to clean out the system. X3
Re: Radiator leak
[Re: 1fastrunner]
#3175491
09/15/23 09:23 PM
09/15/23 09:23 PM
TJP
Omaha Ne
So a hose will do all that from the top? I'll make sure the heater is on when I do that. It will definitely help. Ideally one should pull the block drain plugs but they can be cantankerous ( ) Pulling the T/stat is less effective but better than not. Would've been best to do before having the radiator done . If you do hose it, i'd follow up with a distilled water flush (2 or 3 gallons) to get rid of the crap in the city water.
Re: Radiator leak
[Re: TJP]
#3175673
09/16/23 03:27 PM
09/16/23 03:27 PM
Posts: 10,757 North Dakota
6PakBee
North Dakota
The ethylene glycol never wears out unless it's been excessively overheated. Power plants in northern climates typically use an ethylene glycol heat transfer fluid for air preheating that never gets changed. All that is done is that the corrosion inhibitor is checked and replenished. As to automotive anti-freeze, with the current cost of the stuff, I'll drain it, filter it, throw in a bottle of corrosion inhibitor and put it back in.
Re: Radiator leak
[Re: 6PakBee]
#3175782
09/17/23 09:51 AM
09/17/23 09:51 AM
Posts: 4,789 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I had a 440 Challenger radiator re cored in April 1990. I was making $6.60 per hour. Cost $220. I can only imagine what it costs now. Probably tripled or more.
Keep old mopars alive.
