Indy Tunnel Ram tops
#3173680
09/08/23 02:26 AM
09/08/23 02:26 AM
Posts: 6,145 Melbourne , Australia
LA360
Hello All, a question for the brains trust.
How many different bolt patterns are there for the Indy Tunnel Ram intake manifolds? So far I have encountered two. I did a new top for a Hemi version recently, it was longer than the RB Wedge intake I did about 10 years ago. A few people on the board have mentioned that there are a few variations.
Thanks in advance
Alan Jones
Re: Indy Tunnel Ram tops
[Re: LA360]
#3173749
09/08/23 10:51 AM
09/08/23 10:51 AM
Posts: 4,569 Motor City
6PKRTSE
Motor City
I made my own top with anti reversion plates and also a white nylon spacer. I made several spacers to play with plenum volumes. It didn't seem to matter. The intake is tall enough already. It does seem to help keep the carbs much cooler even by touch is noticeable.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: LA360]
#3173766
09/08/23 11:52 AM
09/08/23 11:52 AM
Posts: 2,924 A shed in England
Tig
A shed in England
As far as I can find out there are only 2 Indy T/R available for the R/B. The newer type has 12 bolts (as per your photo's) I can't recall if the older type has more or less bolts but the question has been asked before and a search may reveal the answer.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3173850
09/08/23 07:17 PM
09/08/23 07:17 PM
Posts: 5,618 long island NY
Ari440
long island NY
Has anyone ever done a single 4500 top plate on a tunnel ram
Any results for a 4500 single
1.39 9.85 - 137 mph
[Re: Ari440]
#3173872
09/08/23 08:19 PM
09/08/23 08:19 PM
6PKRTSE
Motor City
I made one with a Single 4500 flange. Never did a dyno comparison. I just decided that a Hemi has to have dual four barrels.
[Re: 6PKRTSE]
#3173919
09/09/23 01:20 AM
09/09/23 01:20 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
My old school low deck Indy t ram uses 20 #10 screws to fasten the lid. The later versions, IIRC, used 14 1/4" fasteners.
[Re: Ari440]
#3174308
09/10/23 11:22 PM
09/10/23 11:22 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Any results for a 4500 single Likely to have mixture issues with a single TR.
[Re: Jeremiah]
#3174326
09/11/23 03:52 AM
09/11/23 03:52 AM
Posts: 4,647 aotearoa
rebel
aotearoa
My old school low deck Indy t ram uses 20 #10 screws to fasten the lid. The later versions, IIRC, used 14 1/4" fasteners. I bought an older Indy Tunnel Ram that was like that. I compared it to a later model one & think the plenum design looked better. I ended up converting it to EFI. Sure does get some looks.
[Re: LA360]
#3174329
09/11/23 07:06 AM
09/11/23 07:06 AM
Posts: 22,696 Bitopia
jcc
Bitopia
That CNC dual TR top is very nice, But I question its design, other than maybe weight considerations, and all the creativity CNC allows, I wonder why the underside does not take into consideration a gentler air flow path, maybe like a tapered card spacer does on the underside. especially in regards to its sidewalls.?
[Re: jcc]
#3174423
09/11/23 02:20 PM
09/11/23 02:20 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
That CNC dual TR top is very nice, But I question its design, other than maybe weight considerations, and all the creativity CNC allows, I wonder why the underside does not take into consideration a gentler air flow path, maybe like a tapered card spacer does on the underside. especially in regards to its sidewalls.? Wel since it is for an EFI system nothing under it really matters. It is a DRY intake and I see nothing wrong with the undersaide of the top what so ever.
[Re: Al_Alguire]
#3174426
09/11/23 02:24 PM
09/11/23 02:24 PM
jcc
Bitopia
Well. it's a fact moving air (wet or dry) likes to stay in motion and transitions are best when gentle as possible, and that is not the case with that TR top.
[Re: jcc]
#3174429
09/11/23 02:36 PM
09/11/23 02:36 PM
Al_Alguire
Las Vegas
And having been down this road I see ZERO issues with it. I prefer to work from practice not theory. When it comes to carbs and wet intakes with a carb you woudl want to see a shear plate that protrudes into the plenum, the bottom the intake will affect nothing.
[Re: Al_Alguire]
#3174450
09/11/23 03:30 PM
09/11/23 03:30 PM
jcc
Bitopia
I thought the opening pic here was of an EFI application, my bad.
[Re: jcc]
#3174568
09/11/23 11:08 PM
09/11/23 11:08 PM
LA360
Thanks for the pic Rebel, the older style is obviously very different to the current stuff.
JCC, I'm with Al on this, I go with what I know works and what I test, not what I think will work.
Cheers all.
Alan Jones
[Re: feets]
#3174577
09/12/23 12:18 AM
09/12/23 12:18 AM
LA360
Any results for a 4500 single Likely to have mixture issues with a single TR. There are drag racing classes filled with intakes like this, they're not that much more down on power, compared to dual carbs. They're better than a cast single 4 barrel intake in most cases.
Alan Jones
[Re: LA360]
#3174973
09/13/23 03:53 PM
09/13/23 03:53 PM
Posts: 4,058 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Any results for a 4500 single Likely to have mixture issues with a single TR. There are drag racing classes filled with intakes like this, they're not that much more down on power, compared to dual carbs. They're better than a cast single 4 barrel intake in most cases. Sorry I haven't logged-in in a while to add anything but as you see there are probably 3 different bolt patterns (possibly more) but the castings I've seen in the last 10+ years have carried the same pattern. I personally don't think this T/R is a good candidate for a single top. Mainly because air doesn't like to turn more than 12* by the time you made a billet top even somewhat respectful of this the engine CID would have to be BIG and the assembly would be 'ludicrous-tall'. There are some good high-end options for a single-4 RB, probably the best is the 3x.
