Denso 90A alternator - IG amp draw #3173173
09/05/23 04:47 PM
09/05/23 04:47 PM
Chicago area
Magnum GT Offline OP
Chicago area
Hello,
Does anyone know the amp draw on the IG wire (12V key on) for the Denso 90A alternator? I've searched the net and can't find any conclusive number.
Thank you,
Steve
Steve
1979 Magnum GT
2011 1500
Re: Denso 90A alternator - IG amp draw [Re: Magnum GT] #3173201
09/05/23 07:05 PM
09/05/23 07:05 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That would depend on the output of the alternator.
More alternator output means more field current.
Re: Denso 90A alternator - IG amp draw [Re: Magnum GT] #3173239
09/06/23 12:07 AM
09/06/23 12:07 AM
AndyF Offline
AndyF  Offline
Whatever it is it isn't much. Look at an OEM harness in the wrecking yard and you'll see that they don't use heavy wire. Probably 16 or 18 ga. If the OEM guys aren't worried about it then hot rodders don't need to worry about it.
Re: Denso 90A alternator - IG amp draw [Re: Magnum GT] #3173245
09/06/23 03:55 AM
09/06/23 03:55 AM
Cab_Burge Online work
Cab_Burge  Online Work
Buy a good 0 to 100 amp gauge and find out up wrench scope up
Please let us know also luck
Re: Denso 90A alternator - IG amp draw [Re: Cab_Burge] #3173358
09/06/23 02:00 PM
09/06/23 02:00 PM
Chicago area
Chicago area
Thank you everyone.
Cab-That will be a while. Drivetrain is out of the car and I'm laying out the wiring plans for the EFI, ignition, in tank pump and Denso conversion.
What am I doing....
Steve
1979 Magnum GT
2011 1500
Re: Denso 90A alternator - IG amp draw [Re: Magnum GT] #3173424
09/06/23 06:02 PM
09/06/23 06:02 PM
AndyF Offline
AndyF  Offline
You can probably find a schematic on line for a car with a 90A alternator in it. The schematic will show you the wire sizes that the OEM engineers used. I'd trust that information over anything else.
Re: Denso 90A alternator - IG amp draw [Re: AndyF] #3173588
09/07/23 02:46 PM
09/07/23 02:46 PM
Chicago area
Chicago area
Thanks Andy, good idea. I looked at some schematics and although the wire gauge wasn't indicated, I did find a few that show a 7.5A fuse in the ignition line. I took a look at your website for the 90A alternator install instructions and I see what you mean regarding small wire gauge on the pigtail connector.
Steve
1979 Magnum GT
2011 1500
Re: Denso 90A alternator - IG amp draw [Re: Magnum GT] #3173985
09/09/23 11:33 AM
09/09/23 11:33 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
The load pulls mostly away from the battery. The wire for the alternator is rated for the amount of amps going to the battery. The length of the wire is also factored in. If you want to check the amps running threw the wire you need a DC amp probe. The load on the battery will effect output.
[img]https://mowgli-adventures.com/wp-content/uploads/2021/02/Wire-gauge-calculator-table.jpg.webp[/img]
Re: Denso 90A alternator - IG amp draw [Re: Moparite] #3174052
09/09/23 03:56 PM
09/09/23 03:56 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by Moparite
Quote
You didn't understand the question.
Re: Denso 90A alternator - IG amp draw [Re: Sniper] #3174228
09/10/23 02:39 PM
09/10/23 02:39 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Maybe I don't, IG wire? Ignition wire? The alternator had nothing to do with the draw of the ignition. A amp probe will tell you the draw on any wire.
[video:youtube]https://www.youtube.com/watch?app=desktop&v=VNZgm0hatzU[/video]
Re: Denso 90A alternator - IG amp draw [Re: Moparite] #3174238
09/10/23 03:41 PM
09/10/23 03:41 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Quote
What feeds the (usually) blue wire that connects to one of the field terminals?
The ignition circuit. The other field terminal connects to the regulator green (usually) wire.
Re: Denso 90A alternator - IG amp draw [Re: Sniper] #3174408
09/11/23 01:16 PM
09/11/23 01:16 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Blue wire(one going to the regulator) is battery power(key on), The green is the way the regulator "regulates" the alternator output. This is relatively low amperage and the regulator varies voltage to the field to control output.
Re: Denso 90A alternator - IG amp draw [Re: Moparite] #3174500
09/11/23 05:22 PM
09/11/23 05:22 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Quote
The blue wire is the IGNITION ONE circuit.
That's how the factory labeled it, that's how the OP referred to it. You can call it a ham sandwich if you want, but no one's going to have it for lunch.
Re: Denso 90A alternator - IG amp draw [Re: Sniper] #3175171
09/14/23 01:45 PM
09/14/23 01:45 PM
Chicago area
Chicago area
For those interested, I found the following link interesting. It provides a good operational description of Toyota alternators:
http://wilbo666.pbworks.com/w/page/39441708/Toyota%20Alternators
Steve
1979 Magnum GT
2011 1500
Re: Denso 90A alternator - IG amp draw [Re: Magnum GT] #3175209
09/14/23 05:24 PM
09/14/23 05:24 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Good link.
So the “IG” wire on Denso alternators only has to carry enough current to “bias on” a transistor switch inside the Regulator IC Chip - probably a low current.
Re: Denso 90A alternator - IG amp draw [Re: 360view] #3175237
09/14/23 07:40 PM
09/14/23 07:40 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by 360view
Good link.
Only if it's an internally regulated alternator though, which may or may not apply to the OP's alternator because Denso made both styles.
Re: Denso 90A alternator - IG amp draw [Re: Magnum GT] #3175276
09/15/23 12:12 AM
09/15/23 12:12 AM
Originally Posted by Magnum GT
Thank you everyone.
What am I doing....
Me too, realcrazy grin on two cars under construction, one drag race (150.00+ MPH 1/4 mile, 130 MPH in the 1/8 mile) only and the other street only realcrazy shruggy
Re: Denso 90A alternator - IG amp draw [Re: 360view] #3175293
09/15/23 07:44 AM
09/15/23 07:44 AM
USA
3
360view Offline
360view  Offline
3
USA
How many horsepower does an alternator consume at high rpm during a quarter-mile run?
Guess maybe max of
90 amps x 14 volts divided by .85 efficiency = 1482 watts
1492 divided by 745 watts per horsepower
= 2
but could a gain of two win by a distance of a inch to a foot at the finish line.....
at real high rpm the belt/pulley efficiency might be way less than 85%
Re: Denso 90A alternator - IG amp draw [Re: Sniper] #3175310
09/15/23 09:12 AM
09/15/23 09:12 AM
Chicago area
Chicago area
Yes, 90A alternator, internally regulated. AndyF's (AR Engineering) conversion.
Steve
1979 Magnum GT
2011 1500
