Can you use a new stock time chain with Edelbrock Cam? #3173405
09/06/23 04:53 PM
09/06/23 04:53 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I may be putting the edelbrock performer-plus cam and lifter kits 2177 in my 72 dart 318,..Do you got to buy the edelbrock performer timing chain Or can you use a new stock double roller? https://www.jegs.com/i/Edelbrock/350/2177/10002/-1
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Hoop] #3173410
09/06/23 05:19 PM
09/06/23 05:19 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I want to say small block cams just have the one bolt hole that holds the fuel pump eccentric and timing chain sprocket to the face of the cam. Any timing set should be ok if that is the case.
I think it's the BB engines that have cams that use a different number of bolts?
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Neil] #3173415
09/06/23 05:30 PM
09/06/23 05:30 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
There is no need to use the Edelbrock timing set, however, I have found that the "stock replacement" kits tend to wear out fast and the Edelbrock ones hold up, but it's been a few decades since I did an LA cam swap or timing chain replacement.
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Sniper] #3173432
09/06/23 06:21 PM
09/06/23 06:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Spend the few extra bucks on a good timing chain and gears. The cost isn't significant.
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Stanton] #3173434
09/06/23 06:25 PM
09/06/23 06:25 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I've been using the Edelbrock timing chain sets for many years now even in an otherwise stone stock engine if they make one for what I'm working on at any given moment
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: volaredon] #3173458
09/06/23 08:23 PM
09/06/23 08:23 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd run a Rollmaster in there.
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Hoop] #3173648
09/07/23 09:17 PM
09/07/23 09:17 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Not what you asked but FWIW I had that same air cleaner on a car of mine 30 years ago. Can't remember exactly but I think it picked up 4mph or so removing it at the track.
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: INTMD8] #3173650
09/07/23 09:43 PM
09/07/23 09:43 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Not to mention the element is real good at catching fire if one happens to have a stack fire 🔥🔥😲 twocents
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Neil] #3173669
09/08/23 12:28 AM
09/08/23 12:28 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Well, I all ready got a new HEAVY DUTY DOUBLE ROLLER TIMING SET off ebay because I was going to go with a stock cam, but then I was having a had time getting ahold of one, keep getting out of stock & refunded, so I order the edelbrock one from the auto parts, then I read this on jegs! "Do not use late model timing chain and gear sets that are designed for emission-controlled engines. They are machined in a retarded position and are not recommended for this camshaft installation. Use Performer-Link Timing Chain Gear Set 350-7803 or similar set."... This is the one I got off eBay, so I'm wondering should I use it or get the edelbrock one? https://www.ebay.com/itm/133134084872
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Hoop] #3173679
09/08/23 01:40 AM
09/08/23 01:40 AM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
That chain should be fine... the ebay one.
STOP POTATO HATE!
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Hoop] #3173697
09/08/23 08:00 AM
09/08/23 08:00 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We used the stock type timing chain on our 318 hop up / rebuild. We used a cam chain tensioner and I hear double rollers will wear the plastic slipper quickly.
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Stanton] #3173705
09/08/23 08:51 AM
09/08/23 08:51 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Actually went and looked. The stock replacement Cloyes timing set (this is the one I mentioned wears out quickly) is one third the cost of the Edelbrock set and less than one quarter the price of the Rollmaster someone else mentioned.
Cloyes $28.99
Edelbrock $92.95
Rollmaster $133.75
Not exactly insignificant, up front anyway. Since you'll be replacing it in 6 months due to slop it works out to be cheaper to step up to a good one from the get go.
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Hoop] #3173722
09/08/23 09:24 AM
09/08/23 09:24 AM
N
NITROUSN Offline
NITROUSN  Offline
N
You should degree every one. I trust none.
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: NITROUSN] #3173765
09/08/23 11:45 AM
09/08/23 11:45 AM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Did you folks look at the pic of his car? Read his posts, look at the cam link he posted? Its a stocker with oem manifolds and AC and hes putting in a near stock cam. Oem springs? Looks like the not so super high rpm street master intake?
That ebay set he bought is the same as the older oem double roller and is currently sold under one of maybe 10 brand names made by the same vend.
Here is one from the 80-s (sealed power) and is simply an oem replacement. More or less the same as today, maybe a bit better chain maybe not.
Is easy to spend others money and I think we all forget what we did before the internet.
Anyone here posting ever break a oem double roller in a stock motor?
So I should not use the one in my pics in a stock 340 build? Baaa.... craziness. Yea roll masters are good if your spinning 7500 with roller cam springs, they are a much better race made setup. Never had an issue with one but what requires a simple street car to have one in it? How dumb would one look if you went to a weekend show and while looking at a near stock 318 the owner pops off... its got a roll master chain/ billet gear set...... then folks would be silently asking themselves "WHY". Thats 350 chevy guy craziness.
STOP POTATO HATE!
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Mr PotatoHead] #3173772
09/08/23 12:26 PM
09/08/23 12:26 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I used that chain with a 600 lift solid roller back in the day....
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: B1MAXX] #3173783
09/08/23 01:12 PM
09/08/23 01:12 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Always cheaper to get a known good brand the first time. Unfortunately you might be buying a top shelf part to get the job done. My time is worth a lot, so 100 bucks extra for the better one is cheap.
I want my fair share
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: SomeCarGuy] #3173789
09/08/23 01:31 PM
09/08/23 01:31 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Buy once, cry once, install once.
Word seems to be getting out that replacement parts have really bad quality problems (features?). I follow a repair shop on YT and the owner recently trashed some parts by brand name.
Personally for me, Dorman stuff has gotten really bad. Lots of members here have bad Moog stories.
btw
Timing chains seem to do better if you immerse the set in a pan of 30w and heat to 250-300 or so for an hour or 2, then let cool.
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: A990] #3173795
09/08/23 02:10 PM
09/08/23 02:10 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
drive
STOP POTATO HATE!
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Mr PotatoHead] #3173807
09/08/23 03:44 PM
09/08/23 03:44 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yeah, the Cloyes crap I put in a stock 318, stock cam and springs. In 6 months the chain was sloppy enough to require replacement. Looks just like the one in the Ebay pictures to me, btw at Rockauto the Cloyes is half the price of the Ebay one, identical right down to the markings. But hey, replacing a timing set in the car is a rite of passage, right?
What was it Forrest Gump's mama used to say?
Re: Can you use a new stock time chain with Edelbrock Cam? [Re: Sniper] #3173818
09/08/23 04:18 PM
09/08/23 04:18 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You know what I find interesting. Is how would someone know if any part installed in their engine is worn out in 6 months? And secondly how sloppy is to sloppy? Chains tend to loosen up and function just fine. If some here saw some bracket engines that have been together for years and 1000's of passes they'd have a heart attact. It's amazing what you can get away with.
Doug
